This teardown is not a repair guide. To repair your Toy Microscope, use our service manual.
  1. Toy Microscope Teardown, Toy Microscope Teardown: step 1, image 1 of 3 Toy Microscope Teardown, Toy Microscope Teardown: step 1, image 2 of 3 Toy Microscope Teardown, Toy Microscope Teardown: step 1, image 3 of 3
    • The microscope package (that's right, some items were lost and the box suffered)
    • The back of the box with all its items.
    • The useful piece of the microscope package: the microscope (not very surprising...)
  2. Toy Microscope Teardown: step 2, image 1 of 3 Toy Microscope Teardown: step 2, image 2 of 3 Toy Microscope Teardown: step 2, image 3 of 3
    • Now, let's begin the operation: we'll begin with the pedestal. No need for screwdrivers, you just have to pull it.
    • After this, there's a screw. Let's remove it.
    • Once you did it, the battery compartment can be removed.
    • Note: if you want to remove the pedestal completely, you may need to cut the both wires.
    • Note 2: from now on, the microscope will be more difficult to reassemble.
  3. Toy Microscope Teardown: step 3, image 1 of 3 Toy Microscope Teardown: step 3, image 2 of 3 Toy Microscope Teardown: step 3, image 3 of 3
    • Then, this rotative piece is, in a side, a mirror and in the another, a lamp (hence the 1.5x2 batteries in the step 2).
    • To remove it, you need pull a side. The rest will come alone.
    • The picture is a little fuzzy but we can see:
    • The bulb.
    • The support of this rotative piece.
    • The battery.
    • The cover which prevents the bulb to fall.
    • The mirror and the bulb location
  4. Toy Microscope Teardown: step 4, image 1 of 2 Toy Microscope Teardown: step 4, image 2 of 2
    • Now, remove the big Phillips screw here (actually, you can loosen it then remove the nut in the other side). Don't be worried if it's a little hard to pull the screw.
  5. Toy Microscope Teardown: step 5, image 1 of 2 Toy Microscope Teardown: step 5, image 2 of 2
    • Next step: remove the plate (it's here that you put the item to analyze): 2 Phillips screws.
  6. Toy Microscope Teardown: step 6, image 1 of 3 Toy Microscope Teardown: step 6, image 2 of 3 Toy Microscope Teardown: step 6, image 3 of 3
    • This piece allows you to change the growth. 1 screw.
    • If you turn this piece, the growth will be modified thanks to these magnifying glasses (red circles)
    • To remove them, you need to use a sharp piece (e.g a pen) and press on the 3 holes marked on blue.
  7. Toy Microscope Teardown: step 7, image 1 of 1
    • You can easily pull off the black part.
  8. Toy Microscope Teardown: step 8, image 1 of 1
    • After removing the black part (step 6), turn the wheel until you withdraw the lens.
  9. Toy Microscope Teardown: step 9, image 1 of 2 Toy Microscope Teardown: step 9, image 2 of 2
    • This mechanical wheel allows you to hang over or hold off the lens in order to improve the clearness.
    • If you like unscrew whatever you find, there are 2 screws.
  10. Toy Microscope Teardown: step 10, image 1 of 2 Toy Microscope Teardown: step 10, image 2 of 2
    • Now, let's analyze the lens.
    • You just have to pull the different parts.
  11. Toy Microscope Teardown: step 11, image 1 of 2 Toy Microscope Teardown: step 11, image 2 of 2
    • The lens which enlarges the item to analyze from 12 to 18 times.
    • A tube, without magnifiers.
  12. Toy Microscope Teardown: step 12, image 1 of 1
    • Here, that was the consequences when you lend me a microscope. RIP.
    • In the bottom right corner, you can see the perpetrators of this teardown.
Bob
760 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 6,716
