Teardown
This teardown is not a repair guide. To repair your Toy, use our service manual.
This is how the toy truck look before starting the takedown process
Using a big phillips screwdriver unscrew the housing that holds the wheels
Use a small phillips screw driver to unscrew the circuit board
Detach all the parts, including the wheels and truck top.
Once you detach the car top you remove the case that is covering the base of the car
Use wire snips to cut the batteries from the circuit board
with 2 other contributors
119 Reputation
1 Guide authored
Badges: 0
Choose a size and copy the code below to embed this guide as a small widget on your site / forum.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 13
All Time: 1,352
