This teardown is not a repair guide. To repair your Trolltech Greenphone, use our service manual.
  1. Trolltech Greenphone Teardown, Trolltech Greenphone Teardown: step 1, image 1 of 2 Trolltech Greenphone Teardown, Trolltech Greenphone Teardown: step 1, image 2 of 2
    • here is the Qtopia green phone.
  2. Trolltech Greenphone Teardown: step 2, image 1 of 2 Trolltech Greenphone Teardown: step 2, image 2 of 2
    • first, remove the mini-SD card from the side of the phone.
  3. Trolltech Greenphone Teardown: step 3, image 1 of 3 Trolltech Greenphone Teardown: step 3, image 2 of 3 Trolltech Greenphone Teardown: step 3, image 3 of 3
    • then, remove the battery from the phone
    • Unlocking the switch for the battery cover is a little difficult.
  4. Trolltech Greenphone Teardown: step 4, image 1 of 3 Trolltech Greenphone Teardown: step 4, image 2 of 3 Trolltech Greenphone Teardown: step 4, image 3 of 3
    • when the battery is removed, remove the pencil from the device
  5. Trolltech Greenphone Teardown: step 5, image 1 of 3 Trolltech Greenphone Teardown: step 5, image 2 of 3 Trolltech Greenphone Teardown: step 5, image 3 of 3
    • this picture shows the two black plastic clips wich you want du unlock if you would like to reach deeper into the interiors of this phone.
    • the 2e pikture show how to place the slotted pan head screwdriver
    • to unlock them you have to turn the screwdriver around its own axe.
    • when you unlocked both, go with an ipod opening tool around the 3 other sides to unlock several other plastic clips, wich shold be easy to do
  6. Trolltech Greenphone Teardown: step 6, image 1 of 1
    • now your phone should look like this.
    • there is one seperate little silver plastic switch for the camera lense.
    • don't lose that
  7. Trolltech Greenphone Teardown: step 7, image 1 of 3 Trolltech Greenphone Teardown: step 7, image 2 of 3 Trolltech Greenphone Teardown: step 7, image 3 of 3
    • now remove the only 4 screws in this froggy device.
    • the both on the upper part
    • and at the both at the bottom part
    • and see them lie next to the device
  8. Trolltech Greenphone Teardown: step 8, image 1 of 3 Trolltech Greenphone Teardown: step 8, image 2 of 3 Trolltech Greenphone Teardown: step 8, image 3 of 3
    • now insert an ipod opening tool between the (green) front and the black stripe in the center of the phone
    • be careful, the front is fragile
    • as you are gone around its sides, you can simply disassemble the front panel without disconnecting anything.
  9. Trolltech Greenphone Teardown: step 9, image 1 of 2 Trolltech Greenphone Teardown: step 9, image 2 of 2
    • now you are able to put the mainboard (the one and only), display and buttons (it appears that this is one huge part) and the black back/mid frame from each other
    • its easy to remove the speaker/antenna and some plastic parts from the back panel
    • the camera is glued on the board, but connected with an usual camera connector.
    • all EMI shields are brazed onto the bord.
  10. Trolltech Greenphone Teardown: step 10, image 1 of 1
    • this was the whole thing. thank you for reading this far.
    • fancy phone this is!
lon
2,873 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 3,821
