This teardown is not a repair guide. To repair your Tt Esports Poseidon Z KB-PIZ-KLBLUS-06, use our service manual.
  1. Tt Esports Poseidon Z KB-PIZ-KLBLUS-06 Teardown, Remove Keys: step 1, image 1 of 3 Tt Esports Poseidon Z KB-PIZ-KLBLUS-06 Teardown, Remove Keys: step 1, image 2 of 3 Tt Esports Poseidon Z KB-PIZ-KLBLUS-06 Teardown, Remove Keys: step 1, image 3 of 3
    • Use the key cap remover to pry off keys from keyboard
    • Insert firmly to hear click and pull straight out of keyboard
  2. Tt Esports Poseidon Z KB-PIZ-KLBLUS-06 Teardown: step 2, image 1 of 3 Tt Esports Poseidon Z KB-PIZ-KLBLUS-06 Teardown: step 2, image 2 of 3 Tt Esports Poseidon Z KB-PIZ-KLBLUS-06 Teardown: step 2, image 3 of 3
    • The space, +, enter, shift, insert, and backspace keys all have metal parts which increase removal difficulty
    • Tilt key up to disengage the metal latch
  3. Tt Esports Poseidon Z KB-PIZ-KLBLUS-06 Teardown, Back Panel: step 3, image 1 of 3 Tt Esports Poseidon Z KB-PIZ-KLBLUS-06 Teardown, Back Panel: step 3, image 2 of 3 Tt Esports Poseidon Z KB-PIZ-KLBLUS-06 Teardown, Back Panel: step 3, image 3 of 3
    • Flip keyboard over
    • Use standard Philips screwdriver to remove the three back screws from casing
  4. Tt Esports Poseidon Z KB-PIZ-KLBLUS-06 Teardown: step 4, image 1 of 2 Tt Esports Poseidon Z KB-PIZ-KLBLUS-06 Teardown: step 4, image 2 of 2
    • Unclip the two halves of the keyboard case by prying at the following points
    • Need to disengage the plastic tabs holding the two sides of the casing together
  5. Tt Esports Poseidon Z KB-PIZ-KLBLUS-06 Teardown, Motherboard: step 5, image 1 of 2 Tt Esports Poseidon Z KB-PIZ-KLBLUS-06 Teardown, Motherboard: step 5, image 2 of 2
    • Expose the motherboard and internal keys
Timothy
183 Reputation
1 Guide authored
Cal Poly, Team S23-G5, Livingston Spring 2017 Member of Cal Poly, Team S23-G5, Livingston Spring 2017
CPSU-LIVINGSTON-S17S23G5
3 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 904
