This teardown is not a repair guide. To repair your Uniden EXP 371, use our service manual.
  1. Uniden EXP 371 Teardown, Uniden EXP 371 Teardown: step 1, image 1 of 1
    • Uniden EXP371 900 MHz Cordless Phone.
    • 900 MHz Extended Range with One Touch RocketDial/Find Handset Locator and is Desk or Wall Mountable.
  2. Uniden EXP 371 Teardown: step 2, image 1 of 2 Uniden EXP 371 Teardown: step 2, image 2 of 2
    • Remove the battery by first pressing down on the rear of the cover and pushing the cover towards the bottom of the phone.
    • Next remove the battery by pulling on the connector.
  3. Uniden EXP 371 Teardown: step 3, image 1 of 2 Uniden EXP 371 Teardown: step 3, image 2 of 2
    • Next remove the two screws at the bottom of the phone with a PH1 philips screwdriver.
    • Now remove the top portion of the case from the bottom. This may be difficult to do with your bare hands. The use of a plastic opening tool may come in handy.
  4. Uniden EXP 371 Teardown: step 4, image 1 of 3 Uniden EXP 371 Teardown: step 4, image 2 of 3 Uniden EXP 371 Teardown: step 4, image 3 of 3
    • Your next step is to remove the five screws holding down the motherboard. Use the PH1 philips screwdriver.
    • Once you have removed the five screws you may lift the motherboard off of the front case.
    • At this point you may also remove the dial pad. It simply lifts off.
    • You may also remove the speaker if needed by unscrewing the two screws using the PH1 philips screwdriver.
    • The whole phone is now disassembled at this point.
Tim Reimer
165 Reputation
3 Guides authored
One Comment
this guide is poorly written, please delete or improve it.
Walker Quine - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 4,588
