This teardown is not a repair guide. To repair your Wii Balance Board, use our service manual.
  1. Wii Balance Board Teardown, Wii Balance Board Teardown: step 1, image 1 of 3 Wii Balance Board Teardown, Wii Balance Board Teardown: step 1, image 2 of 3 Wii Balance Board Teardown, Wii Balance Board Teardown: step 1, image 3 of 3
    • First remove the circles from the balance board. The circles are in the corners.
    • Unscrew the 4 circles first then unscrew the middle screws that secure the base.
    • Remove the circles and the base.
    • Don't pull off the big chip or the motherboard, just unscrew the middle so it won't break.
  2. Wii Balance Board Teardown: step 2, image 1 of 2 Wii Balance Board Teardown: step 2, image 2 of 2
    • If you want to take off the motherboard first you have to unscrew the screw in the middle then you can take it off.
  3. Wii Balance Board Teardown: step 3, image 1 of 1
    • Then when you're done, screw back the motherboard in the same place where it was.
  4. Wii Balance Board Teardown: step 4, image 1 of 1
    • When you're done screwing the motherboard in, screw back the middle piece first so you can put it back together.
  5. Wii Balance Board Teardown: step 5, image 1 of 1
    • The last step is to screw in the corners and the circles, and then you will be done.
efraim
117 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 65
All Time: 5,828
