So, what do we have here? This affordable smartphone offers some impressive specs at first glance:
Qualcomm® Snapdragon Quad-Core with 1.2 GHz
2 GB RAM and 16 GB ROM (and additional Micro SD for up to 64 GB)
5 inch IPS Display with 1280x720 pixels
13 megapixels camera with 1080P video recording at 30 fps
USB OTG connection, a standard 3.5mm headphone jack, and an integrated Stereo FM Radio receiver
Android​ 5.1 Lollipop
Dual sim: 1 micro SIM + 1 nano SIM
We line a shift5.1 (left) up next to our Wiko Pulp 4G and see some similarities in their designs.
With the Wiko's official length measuring 143.9 mm from top to bottom, it is only 0.1 mm shorter than the shift5.1.
We played a very simple game of smart phone Jenga with the phones to see how their widths and thickness...stack up to each other.
Both have the same width: 72 mm. The Pulp4G, on top, is 8.8 mm thick, yet it appears thinner than the 7 mm of the shift 5.1, possibly due to its curved edges.
The back cover has a different look but is the same kind of snap off.
This is what makes the Wiko Pulp 4G tick:
Qualcomm MSM8916 CPU with an ARMv8 Cortex-A53
SK Hynix H9TQ17ABJTMC 2 GB RAM and 16 GB NAND flash storage
Skyworks SKY77648-11 multimode multiband power amplifier module
Qualcomm WTR4905 RF transceiver
Qualcomm WCN3620 wireless connectivity IC
SGMicro SGM3140B 500mA buck/boost charge pump LED driver
IC Identification, Continued:
Qorvo RF1496A SP12T Antenna Switch
Skyworks SKY13416-485LF SP6T Antenna Switch
Texas Instruments TPD1S414 USB Charger OVP Switch w/ ESD Protection
ON Semiconductor NCP114AMX310T 300 mA/3.1 V LDO Regulator
Silergy DC-DC Converters
Likely Maxscend GNSS LNA
At the bottom of the display assembly we find a daughter board with some components.
First we disconnect the cable coming from the motherboard and pry out the vibrator.
Next we peel off a small connector plate and disconnect the antenna cable.
Now we are ready to carefully pry out the daughter board itself which is glued in with some double sided tape.
Being able to detach the daughter board completely from the cable (and therefore from the mother board) is a big advantage over the shift5.1.
On the other hand, all of the components are soldered to the board, which makes repairing them individually a bit trickier.
USB port
Vibrator
Microphone
Speaking of the connection cable, we peel off the big sticker and find the second display cable running underneath and directly into the display itself.
With the sticker gone it is possible to also take away the power and volume buttons.
We stop here, leaving the connector cable in place.
- Replacing the battery is easy as pie with the swappable back cover.
- This phone doesn't use excessive glue nor proprietary screws—we found only Phillips throughout the entirety.
- Most of the components can be replaced separately.
- The motherboard and daughterboard are connected via a detachable cable.
- Unfortunately, the components on the daughterboard are soldered on, making a repair on an individual component difficult.
Final Thoughts
Repairability Score
(10 is easiest to repair)
