Introduction
Today a new Xbox lands in our inbox, and that's a rare thing—though not as rare as it used to be. What makes the new Xbox One S a worthy mid-cycle update to Microsoft's console? Let's tear down this surprisingly slimmer, possibly speedier, appreciably sassier Xbox One and find out. Game on!
This teardown season is just getting started—add us on Facebook, Instagram, or Twitter and never miss a beat.
Video Overview
You'd expect some differences from the Day One Edition Xbox One we tore down way back in 2013, and you'd be right. Here's what we know:
Spec-bumped GPU supporting HDR10 along with the same AMD "Jaguar" 8-core SoC found in the original Xbox One.
2 TB of storage (500 GB and 1 TB configurations are coming)
HDMI 2.0a connectivity with support for 4K video at 60 Hz
Internal power supply
IR blaster
Fancy vertical stand (2 TB model only)
Redesigned Xbox Wireless Controller
Etched into the starboard side of the Xbox One S, we find a cute reminder that this console still hails from the other tech capital of the West Coast: "Hello from Seattle," home of the Microsoft brigade.
Moving right along, we discover the Xbox One S is now identified as Model 1681.
In a design decision that takes us back to consoles of old, this One features mechanical buttons in lieu of capacitive ones.
Around back, under the many vent holes we find:
Power inlet
HDMI out (left) and in (right)
Two USB 3.0 ports (in addition to the one on the front)
IR output, optical audio, and Ethernet ports
What about my Kinect, you ask? You can apply for a "free" Kinect USB adapter—provided you already own a Kinect, an original Xbox One, and the Xbox One S.
Our first act of teardown: tamper evident sticker removal. But no screws in sight, just the back of an immobile plastic clip. Bummer.
Make that opening tools—because popping that plastic "security" nub takes a little extra oomph.
Do we like security clips? Not in a box. Not with a fox. Not in a house. Not with a mouse. We do not like them here nor there; we do not like them anywhere.
After some intense prying, we successfully remove the bottom cover, revealing a metal interior case.
Some nostalgic green screws labeled F (for first?) free the primary assembly from the upper case.
This One, more streamlined than its predecessor, doesn't feature any weird, afterthought components left out in the cold.
All that's left in the PC/ABS case are some button covers and Sabic and Samsung logos—probably the plastic suppliers.
Lifting one metal midbody panel reveals a beautiful sight: such nice, sleek components that we are momentarily inclined to keep the cover off forever.
Somebody call the Jackson 5, 'cause identifying these numbered and labeled components is easy as 01-02-03 (and 04).
But wait—who's that we spy?
Master Chief has arrived on a new world, this time to protect the optical disc drive bracket. Hopefully the Flood keeps out of this drive for good.
Much like the RF board on the Xbox One, the front panel board of the Xbox One S detaches outward from the lower case.
With the front panel board's EMI shield removed, we quickly spy a lone IC and some of its friends:
MediaTek MT7632TUN (Likely a variation of MT7632 2x2 802.11n + Bluetooth 4.0 Module)
Skyworks SKY13314-374LF GaAs SPDT Switch
Sync switch for wireless controllers
IR Blaster
Power Switch
Eject switch
Next up on the teardown chopping block is the Wi-Fi board. After removing a few Torx screws, it comes quietly just like the front panel board before it.
This is a nice incremental improvement over its location in the previous Xbox One—it makes for one less step to open the inner metal case.
Wi-Fi is handled by a MediaTek MT7612UN (Likely a variation of MT7612U 2x2 802.11ac Wi-Fi Module)
At this point, component removal is a bit of a hunt, so we extract some screws and see which component is freed first.
Oddly enough, despite being labeled 04, the hard drive is the first component out.
We find a
SamsungSeagate Spinpoint M9T ST2000LM003 2 TB 5400 RPM with 32 MB Cache SATA III 6.0 Gb/s hard drive. Try saying that ten times fast. -
Sadly, hard drive replacements still void the warranty, and need some tricky formatting.
The One S packs a sweet SATA III drive, but it may still be using the SATA II interface of the original Xbox One. You can always add an external hard drive though, thanks Microsoft!
The next to go is number two: the optical drive—too easy! Master Chief is of course along for the ride.
Here we have the artist formally known as a BD-ROM drive, courtesy of Philips and Lite-On Digital Solutions. The DG-6M5S model found in the Xbox One S is slightly different from the DG-6M1S found in the Xbox One, with the biggest upgrade being support for BD-UHD.
We also snag a couple rubber bumpers. These probably help keep the high-speed optical drive from rattling us off our rockers.
Now we come to the One S's hat trick (a.k.a. #03)—a smaller, newly-fanless, neatly-integrated power supply. Gone is that dangling anchor of yore.
Welcome to the club, Xbox One.
This power supply also accepts 100-240 V inputs, meaning you can take it pretty much anywhere there's a socket. Take that, Xbox One!
Things are heating up in the teardown room, but we can't extract the "Thermal System" just yet. So we lift the whole dang motherboard assembly out of the metal casing.
The "X" is a bit fussy and takes some muscle, but some practiced prying with a flathead driver saves the day.
With the component countdown nearly complete, it's time to extract part number 01: the thermal system.
Out comes the system's single 120 mm fan—looking much like a PC case fan, but with some sculpting that's unique to the Xbox One's design.
The backup for the One S's biggest fan is an impressive aluminum heat sink and copper heat pipe set. Cool.
Now on to our One true love, chips!
X949211-001 DG4001FYG87IA (Includes 1.75 GHz AMD "Jaguar" 8-core CPU + overclocked 914 MHz AMD Radeon Graphics GPU)
16 x Samsung SEC 549 K4W4G1646E-BC1A 4 Gb (512 MB) "gDDR3" SDRAM (total of 16 x 512 MB = 8 GB)
X861949-005 T6WD5XBG-0003 Southbridge I/O controller
Toshiba THGBMFG6C1LBAIL 8 GB eMMC NAND flash
ON Semiconductor NCP4205 (Likely an iteration of the NCP4204 Integrated Power Control IC found in the Xbox One) (probably CPU power phase PWM controller)
Texas Instruments SN75DP159 6 Gb/s DP++ to HDMI retimer
STMicroelectronics LDFPT 1 A LDO regulator
And on the back of the motherboard...is not much really.
Realtek RTL8111HM (Likely an iteration of the RTL8111 gigabit ethernet controller)
Nuvoton ISD8104 2 W class AB audio amplifier (likely)
Texas Instruments SN74LVC1G08 single 2-input AND gate
Oh and that handy front-side USB port—which is on the opposite end and opposite side from its friends, poor guy.
Bonus chips:
STMicroelectronics LM339A quad voltage comparator
Texas Instruments TPS51916 memory power controller
Richtek RT9011-JGPQV 300 mA dual LDO regulator
Monolithic Power Systems MP8757GL 7 A / 18 V synchronous step-down converter
Monolithic Power Systems MP2161GJ 2 A / 6 V synchronous step-down converter
ON Semiconductor CAT6243DCADJ 1 A LDO regulator
Diodes Incorporated (formerly BCD Semiconductor) AP2127K-ADJTRG1 300 mA LDO regulator
Now on to the controller!
While we are disappointed by the lack of visible screws, we will celebrate a small concession: the batteries are still user-replaceable! (Looking at you, DualShock 4).
Using our recent console expertise, we bust out the trusty opening tools and pop off some white paneling, finding some sneaky Torx security screws. Boo.
Not only that, but a final Torx security screw is hiding under the battery compartment sticker. Double boo.
Popping off those plastic panels reveals what looks like a neat little assembly, complete with four haptic feedback motors.
But once we start to extract the beast, we see the truth: Unless you're handy with a soldering iron, this is an all-or-nothing disassembly procedure.
We decided to pick option "all" and just lay everything out, still connected.
Beauty is only skin-deep, and so too are this controller's physical changes. Inside, it's largely the same design as the original Xbox One controller—our guides should be relevant for both models.
- Only a few tools are required to take the whole console apart.
- Once inside, a clean, no-nonsense modular design allows the drives, fan, heat sink, PSU, wireless board, and front daughterboard to be easily replaced.
- Fewer interlocking body panels and a simpler clip arrangement make opening this generation of Xbox easier than its senior.
- Replacing the hard drive will require both voiding your warranty and some difficult hackery to make it serviceable.
Final Thoughts
Repairability Score
![](https://assets.cdn.ifixit.com/static/images/repairability_meter/meter-background.png)
![](https://assets.cdn.ifixit.com/static/images/repairability_meter/meter.png)
(10 is easiest to repair)
56 Comments
My question is whether the SATA controller on the motherboard is a SATA III interface; the tear down guide (which is great btw!) only mentions that the 2TB hard drive itself is SATA III. According to the Xbox One (original) tear down guide and this tear down guide, both the Xbox One and Xbox One S use the same south bridge; which would imply that the Xbox One S is only capable of SATA II speeds, regardless of the fact it holds a SATA III drive.
I Googled the X861949 southbridge and it's the exact same one as in the first Xbone.
It hardly matters; no HDD is going to get anywhere near the limits of the SATA II bus, let alone the SATA III bus. You need a seriously fast SSD to start seeing a difference there, and AFAICT the XBone's OS isn't set up to do TRIM, which would limit the lifespan.
