This teardown is not a repair guide. To repair your Xbox One Wireless Controller Model 1537, use our service manual.
  1. Xbox One Wireless Controller Teardown, Get an Xbox One Controller: step 1, image 1 of 1
    • Start off with having an Xbox One Controller (:
  2. Xbox One Wireless Controller Teardown, Remove First Screw: step 2, image 1 of 2 Xbox One Wireless Controller Teardown, Remove First Screw: step 2, image 2 of 2
    • Start with removing the battery pack and exposing the T8 security screw. The screw should be hidden behind a warranty sticker.
  3. Xbox One Wireless Controller Teardown, Remove side panels: step 3, image 1 of 3 Xbox One Wireless Controller Teardown, Remove side panels: step 3, image 2 of 3 Xbox One Wireless Controller Teardown, Remove side panels: step 3, image 3 of 3
    • Remove the side panels exposing the second T8 security screw using a spudger, an IFixit Opening Tool, or your nails, each choice is fun.
  4. Xbox One Wireless Controller Teardown, Remove all screws: step 4, image 1 of 1
    • By removing all side panels all 5 TR8 security screws have appeared!
  5. Xbox One Wireless Controller Teardown, Remove Faceplate: step 5, image 1 of 3 Xbox One Wireless Controller Teardown, Remove Faceplate: step 5, image 2 of 3 Xbox One Wireless Controller Teardown, Remove Faceplate: step 5, image 3 of 3
    • Once you removed the T8 security screws remove the front face plate.
  6. Xbox One Wireless Controller Teardown, Tape down rumble motors: step 6, image 1 of 2 Xbox One Wireless Controller Teardown, Tape down rumble motors: step 6, image 2 of 2
    • Tape down the rumbler motors to prevent them from falling out.
  7. Xbox One Wireless Controller Teardown, Remove T6 screws: step 7, image 1 of 3 Xbox One Wireless Controller Teardown, Remove T6 screws: step 7, image 2 of 3 Xbox One Wireless Controller Teardown, Remove T6 screws: step 7, image 3 of 3
    • Remove the T6 screws to remove the PCB's.
    • It takes a pull to seperate the connectors.
    • Watch the wires! You can not fully remove the circuit board without removing the wires and it requires soldering.
  8. Xbox One Wireless Controller Teardown: step 8, image 1 of 3 Xbox One Wireless Controller Teardown: step 8, image 2 of 3 Xbox One Wireless Controller Teardown: step 8, image 3 of 3
    • Remove the top cover, it folds over.
    • There are 6 T6 screws to remove.
  9. Xbox One Wireless Controller Teardown: step 9, image 1 of 3 Xbox One Wireless Controller Teardown: step 9, image 2 of 3 Xbox One Wireless Controller Teardown: step 9, image 3 of 3
    • Remove the circuit board
    • Under the rubber is the A B X Y buttons.
  10. Xbox One Wireless Controller Teardown: step 10, image 1 of 3 Xbox One Wireless Controller Teardown: step 10, image 2 of 3 Xbox One Wireless Controller Teardown: step 10, image 3 of 3
    • Follow the instructions in reverse to get everything together again. :D
ubaldo gutierrez
265 Reputation
1 Guide authored
16 Comments
Very good instructions...
Chadwick Posey - Reply
Nice instructions. I need to take apart mine and replace the d-pad. The previous owner was a bit... rough. Sometimes it doesn't work or it clicks twice. Cheers!
Johnathan - Reply
Do you think that you can label the internals of the controller.
David Becerra - Reply
I have a custom controller from the xbox design labs. I want to change the led on the front.
Can someone point out the model/ size led I would need?
Alajandro - Reply
How do you put the sync buttom back in? Which way does it face?
Throaty Sea5 - Reply
Past 24 Hours: 47
Past 7 Days: 283
Past 30 Days: 1,137
All Time: 183,865
