Teardown
This teardown is not a repair guide. To repair your iClicker, use our service manual.
Remove the battery cover
Remove the two AAA batteries
Remove the three screws using a screwdriver
Remove the back cover
Remove the positive and negative battery contacts using pliers
Remove the circuit board
Remove the soft touch buttons
Full IC Identification:
Predicted Block Diagram is on the 2nd image.
You may need to enlarge it to view the text.
You're done!
with 2 other contributors
708 Reputation
6 Guides authored
Badges: 10
+7 more badges
CPSU-BANGHART-W17S9G4
4 Members
11 Guides authored
Choose a size and copy the code below to embed this guide as a small widget on your site / forum.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 7
All Time: 705
