Introduction
Go to step 1
Think of the most colorful and radiant display you’ve ever seen. Now, discard that memory and stare at Apple’s newest iMac Intel 27” with Retina 5K Display. We're not talking 1080p or 4K, we're talking about 5K—millions and millions of pixels on a 27-inch display. Will the addition of a high-resolution display affect the repairability of the newest iMac Intel 27”? Let’s find out!
Follow us on Facebook, Instagram, or Twitter for the latest teardown news.
Tools
Video Overview
This teardown is not a repair guide. To repair your iMac Intel 27" Retina 5K Display, use our service manual.
  1. iMac Intel 27" Retina 5K Display Teardown, iMac Intel 27" Retina 5K Display Teardown: step 1, image 1 of 2 iMac Intel 27" Retina 5K Display Teardown, iMac Intel 27" Retina 5K Display Teardown: step 1, image 2 of 2
    • How do you herd together 14.7 million pixels? You can ask nicely, or you can brandish some heavy-duty hardware. Inside the Retina 5K iMac:
    • 3.5 GHz quad-core Intel Core i5 processor, with Turbo Boost up to 3.9 GHz
    • 8 GB (2x4 GB) of 1600 MHz DDR3 RAM
    • AMD Radeon R9 M290X graphics processor with 2 GB of GDDR5 video memory
    • 802.11ac Wi-Fi + Bluetooth 4.0
    • PCIe-based SSD storage and SATA hard drive
  2. iMac Intel 27" Retina 5K Display Teardown: step 2, image 1 of 2 iMac Intel 27" Retina 5K Display Teardown: step 2, image 2 of 2
    • Not one to waste a good model number on just a single device, Apple again recycles A1419.
    • For a unique identifier, this is EMC 2806.
    • At the rear of the iMac, we find a plethora of I/O ports and a lone SDXC card slot:
    • Headphone jack / Optical digital audio output
    • SDXC card slot
    • Four USB 3.0 ports
    • Two Thunderbolt 2.0 ports
    • Gigabit ethernet port
    In step 2 photo we can read 'Assembled in USA'
    Will it be the same for all the Retina 5K iMacs? All made in the US?
    mattizeta - Reply
    I wouldnt say all of it is assembled in US. If you look at step 5, it said assembled in china
    john -
    You get to see just how cheap made in china piece of crap it really is
    Terry Vanderpuke - Reply
    Which technology giant do you prefer instead that does not outsource its products to China? Please name one. Then after you can't give me a name of a single one, decide which one builds the best Made in China computer. You will see why Apple iMac has out-paced every other All-in-one computer. They are simply the best in their class (All-in-One).
    Kendrich Heppner -
  3. iMac Intel 27" Retina 5K Display Teardown: step 3, image 1 of 2 iMac Intel 27" Retina 5K Display Teardown: step 3, image 2 of 2
    • Fixers rejoice! The iMac Intel 27" Retina 5K Display retains the familiar, easily accessible RAM upgrade slot from iMacs of yore.
    • For those who require assistance replacing their RAM modules, Apple has attempted to provide some direction—that you get to see after you're halfway through the process.
    • For anyone who would rather be guided by glorious high-resolution images and lovingly crafted text, that's also available.
  4. iMac Intel 27" Retina 5K Display Teardown: step 4, image 1 of 3 iMac Intel 27" Retina 5K Display Teardown: step 4, image 2 of 3 iMac Intel 27" Retina 5K Display Teardown: step 4, image 3 of 3
    Tool used on this step:
    iMac Opening Wheel
    $7.99
    • We're pretty adept at slicing open iMacs with our ever-so-fancy pizza cutter iMac Opening Tool and our noble Plastic Card.
    • While the procedure still requires a steady hand and a willingness to replace the custom-cut, two-sided adhesive tape when you're done, it's otherwise pretty straightforward, and unchanged from previous models.
    • With the adhesive tape gone, we get our first peek at the hardware inside the Retina 5K iMac.
    Do you need to reapply adhesive when you put the screen back in the frame?
    billibala - Reply
    Yep! Here's how to do it on the Late 2013 model: iMac Intel 27" EMC 2639 Adhesive Strips Replacement.
    It'll be the exact same procedure on the Retina 5K.
    Andrew Optimus Goldheart -
    Your missing a pic… Where does the display connect to and how to remove it?
    Tom Jackson - Reply
    If you’re looking for step-by-step instructions, check here. Teardowns aren’t meant to be used as repair guides.
    Jeff Suovanen -
    If I got hold a 2014 5k retina display. Would it work in my late 2015 27 inch iMac?
    Cary B - Reply
  5. iMac Intel 27" Retina 5K Display Teardown: step 5, image 1 of 3 iMac Intel 27" Retina 5K Display Teardown: step 5, image 2 of 3 iMac Intel 27" Retina 5K Display Teardown: step 5, image 3 of 3
    • The first order of business is finding out whether this 5K display runs on actual magic, or something more susceptible to dissection.
    • This particular display was manufactured by LG Display. (So, magic is looking less likely.)
    • With a few twists of our screwdriver, a very long, very thin display board is revealed.
    So is this imac sharing the same LM270QQ1 panel as the future Dell Ultrasharp 5K monitor?
    (same way as the Dell UltraSharp U2711 shared the LM270WQ1 as the normal 27" imac?)
    nikos232 - Reply
    My iMac Late 2013 (non-5K) display damaged need replacement and I'm about to order a new display assembly.
    Silly question, can I replace the standard QHD display with 5K display - will it work?
    autodubai - Reply
    Hi, have you make the change your iMac 27 "late 2013 with 5k ? i have the same and i don't know if works or not !!!
    Thanks
    Smadoiu Florin -
    For any latecomers whom may be wondering if they can just swap in a 5k LCD panel into a non 5k iMac, the answer is NO - It will NOT work. See step #7... the LVDS connectors are different due to different bandwidth requirements.
    Midnight Sparky - Reply
    Where would you buy a replacement 5K panel? If the controller board is damaged, can this also be bought separately?
    Stephan Du Toit - Reply
    I found one of my ribbons on this board is broken. Can't it be replaced?
    Alfonzo Anthony - Reply
  6. iMac Intel 27" Retina 5K Display Teardown: step 6, image 1 of 3 iMac Intel 27" Retina 5K Display Teardown: step 6, image 2 of 3 iMac Intel 27" Retina 5K Display Teardown: step 6, image 3 of 3
    • Let's take a look at the hardware that allows 14.7 million pixels with a resolution of 5120 x 2880 on a 27-inch display:
    • Texas Instruments NH245 8-Bit Dual-Supply Bus Transceiver
    • Texas Instruments BUF16821 Programmable Gamma-Voltage Generator and Vcom Calibrator
    • Parade Technologies DP665 LCD Timing Controller
    • We assume this is an Apple modified version of the DP663 LCD Timing Controller
    • Texas Instruments TPS65270 Monolithic Dual Synchronous Buck Regulator
    • Texas Instruments TPS65168 High Resolution Fully Programmable LCD Bias IC for TV
    Is there no way to hack this part to make it work like a standalone display?
    royrochlin - Reply
    I, like Roy, would like to know if there is an adapter board or pin-out for a displayport, or hdmi (doubtful), connector?
    Perhaps we can squeeze in an ITX board in here one day with the Coffee Lake 4-cores show its age (with 16 core AMDs in ITX low-profile boards available!).
    eduncan911 - Reply
  7. iMac Intel 27" Retina 5K Display Teardown: step 7, image 1 of 3 iMac Intel 27" Retina 5K Display Teardown: step 7, image 2 of 3 iMac Intel 27" Retina 5K Display Teardown: step 7, image 3 of 3
    • Barring the new display, the hardware inside the iMac Intel 27" Retina 5K Display looks much the same as last year's 27" iMac.
    • In fact, as we dive in deeper, we realize it is very nearly exactly the same.
    • We would have documented the logic board removal, but we already have! We'll be following last year's logic board guide—check it out and head back here while we skip ahead.
    • And after following the guide to the letter, we've got our findings on the differences inside:
    • The Retina 5K's display data cable is slightly wider—to support those extra pixels.
    Now, to find an LVDS to DisplayPort adapter logic board... For, you know, those of us that want to swap in a low-profile ITX 16C Ryzen "proper replacement." ;)
    eduncan911 - Reply
  8. iMac Intel 27" Retina 5K Display Teardown: step 8, image 1 of 1
    • Let's see what ICs this unsurprisingly familiar logic board is packing:
    • AMD Radeon R9 M290X GPU
    • Intel Core i5-4690 Processor
    • Just like last year, the CPU is not soldered to the logic board, and can be easily replaced (we just left it in the socket for the picture).
    • SK Hynix H5GC2H24BFR 256 MB GDDR5 SGRAM (256 MB x 8 modules = 2 GB total)
    • Delta Electronics 8904CF 143003
    • Intel DH82Z87 (Z87) Platform Controller Hub
    • Fairchild Semiconductor DE32GV
    What is the model of this logic board and where can I find one? Any idea the model or part number of the 4.0ghz board with 4gb display memory?
    ojcmolloy - Reply
    There is not any cooler in the CPU. Nacked CPU? Maybe the i7 need a cooler and i5 could run without any cooler?
    Very impressive to see a nacked CPU.
    Well done iFixed!
    Fixerr - Reply
    They probably cleaned it for the purposes of photographing it.
    jussnf -
    jussnf is correct, we cleaned off the thermal compound to read the markings.
    See Step 7 ... Logic board removal is another guide. There is a heat sink.
    satishguild - Reply
    Could be very interesting the CPU replacement when the next core i7 appear!
    But will be fully compatible?
    Also could be interesting to buy this iMac, and later go up to the next Mac Pro generations and use this "old iMac" like a Retina Display.
    Faiolo -
    @Faiolo
    These new iMacs can't be used as external displays. The current version of DisplayPort can't handle the bandwidth necessary for 5k displays over a single connector, so Apple decided to cut the feature rather than only support 4k resolution, or require two connectors. So, the screen is stuck with this computer, and you can't use it with any other.
    Cryo -
    The CPU LOOKS upgradable!
    James Katt - Reply
    can this be upgraded to the new 8 core i7 ???
    Paul Rabinowitz - Reply
    Probably not. I believe the processor options available for this have 84 and 88 watt max TDPs, while the 8 core I7 is rated at using up to 140 watts. It would most likely not be able to dissipate the heat under load.
    Cryo -
    Is the headphone socket part of the right speaker assembly? It does not seem to be on the logic board.
    Dominic Dunlop - Reply
    Is the GPU removable for upgrade purposes ?
    I would like to boost the graphics to handle VR :)
    Richard Shine - Reply
    Is that an extra SATA port? Or is that one already used? I did the double SSD upgrade on my 2011- wondering if this one can do it.
    Jordan Shababy - Reply
    It's a single SATA port... But, you don't want to touch that (or just use it for slow storage, like a cheap 2 TB QLC drive).
    Instead, get an NVMe M.2 PCIe adapter, and plop in an PCIe 3.0 NVMe drive and enjoy ~2500 MB/s read/write.
    eduncan911 -
  9. iMac Intel 27" Retina 5K Display Teardown: step 9, image 1 of 1
    • Front side of logic board:
    • Broadcom BCM5776 Gigabit Ethernet Controller
    • Cirrus Logic 4206BCNZ Audio Controller
    • Intel DSL5520 Thunderbolt 2 Controller
    • LMF4S1EH 5BBCIG 47A6HPW
    • Microchip Technology 1428-7 420BE5A BMY System Management Bus (SMBus) Temperature Sensor
    • Intersil ISL6327 Enhanced 6-Phase PWM Controller
    The LMF4S1EH 5BBCIG 47A6HPW is the SMC chip ;-)
    perfaram - Reply
    Here is the correct URL for the Intersil Buck voltage regulator: ISL6327 URL and here is the PDF Spec sheet: ISL6327 PDF
    Dan - Reply
    Unfortunately, that part number for the temperature sensor appears to be invalid. Microchip has no record of any such item. and that link doesn’t go to a product. I have a ticket open with Microchip to try to identify the part correctly, but haven’t heard back yet.
    venusprobe - Reply
    Got the 17,1 iMac and both the 820-3298 and 820-3299 boardviews are like this picture (except GPU RAM) but my board is different.
    Looking at this picture at the bottom of the board there's the J2550. At its right-hand side there's one of the U7000 and different from the picture (and from the boardview) mine has its resistors soldered above it not around. And it was such a huge pain to get it right I don't even know how I managed to get my board working again - can only hope it'll be good enough to last a few years…
    Carlos Ferrari - Reply
  10. iMac Intel 27" Retina 5K Display Teardown: step 10, image 1 of 2 iMac Intel 27" Retina 5K Display Teardown: step 10, image 2 of 2
    • This looks to be the exact same SanDisk PCIe SSD as the one found in the MacBook Pro 13" Retina Display Late 2013.
    • Unsurprisingly, we find the exact same ICs:
    • SanDisk 05131 016G 16 GB NAND Flash (four on each side, total of 8 x 16 GB = 128 GB)
    • SK Hynix H5TQ2G63DFR 2 GB DDR3 SDRAM
    • Marvell 88SS91383 PCIe SSD Controller
    What is this for? Sorry if this is a dumb question.
    radford5000 - Reply
    Apple's Fusion Drive - They combine the SSD and spinning drive into one logical volume. They use various heuristics to then keep the "most frequently used" files stored onto the SSD. Most of the system files wind up on it along with most of my docs it seems.
    modgigcist -
    what connection port is this? the card looks longer than normal full length mini pcie, have a m2 kind of screwing notch, but connector look more like pcie
    dennis97519 - Reply
    A used ssd from a Macbook Pro 13 late 2013 or newer will work with the late 2015 5k imac? And those adapters they sell on eBay to use a regular m2 ssd?
    Alber Einsten - Reply
    Hi, is this the same as the late 2013 iMac? thx
    LApo J - Reply
    What’s the maximum capacity SSD?
    Snarky John - Reply
    Do all 27” Late 2015 iMacs come with an M.2 port to install an ssd card? Or is it only available for the fusion drive models?
    Josh - Reply
  11. iMac Intel 27" Retina 5K Display Teardown: step 11, image 1 of 3 iMac Intel 27" Retina 5K Display Teardown: step 11, image 2 of 3 iMac Intel 27" Retina 5K Display Teardown: step 11, image 3 of 3
    • The AirPort/Bluetooth card, identified by its model number BCM94360CD, is exactly the same as the one we encountered in last year's iMac Intel 27 inch:
    • Broadcom BCM4360KML1G 5G WiFi 3-Stream 802.11ac Gigabit Transceiver
    • Skyworks SE5516 Dual-Band 802.11a/b/g/n/ac WLAN Front-End Module
    • Broadcom BCM20702 Single-Chip Bluetooth 4.0 HCI Solution with Bluetooth Low Energy (BLE) Support
    and what is the connection port for this?
    dennis97519 - Reply
    is there any this port to pcie mini adapter?
    dennis97519 - Reply
  12. iMac Intel 27" Retina 5K Display Teardown: step 12, image 1 of 2 iMac Intel 27" Retina 5K Display Teardown: step 12, image 2 of 2
    • iMac 27" Retina 5K Display Repairability Score: 5 out of 10 (10 is easiest to repair)
    • RAM is user-replaceable without opening the case, thanks to the rear access door.
    • You can still replace the hard drive and CPU inside this machine, albeit with some adhesive cutting.
    • Components are modular and fairly easy to remove.
    • The glass and LCD are fused together, and there are no more magnets holding the glass in place.
    • You'll have to masterfully peel off the old double-sided sticky tape and apply new tape in order to reseal this iMac into original condition.
    A lot of people like me want to buy a standard config model from the store and then upgrade the RAM and Storage ourselves. This teardown story claims this can be done. But I wonder if more information about the storage can be provided.
    The fusion drive looks like a regular hard drive with something plugged into the motherboard. What happens if we replace the regular drive with SSD. Does the Fusion SSD still operate independently, meaning more overall SSD storage? Is anything software related impacted?
    BMan - Reply
    I sort of answered my own question. I want to get the standard iMac so I can take delivery today which means getting a 1TB fusion drive. I was curious about upgrading the regular hard drive part of the fusion drive.
    I'm not so bright so I didn't understand what PCIe was but now I see it is just a card. The Retina SSD is PCIe based....meaning, if you want to upgrade the SSD part of the fusion drive, you simply buy a larger PCIeSSD card. Google Mercury Accelsior E2
    You can also upgrade the old HD part of the equation.
    But here's the thing. There's something even better. You can throw these PCIe based SSD cards into an external enclosure and access then through the Thunderbolt port. That will give you the best possible performance..better than upgrading to Apple's SSD.
    So the short answer is if you are in a hurry and want a new iMac retina 5K, go ahead an buy one knowing you can not only upgrade the internal SSD and HD but also access an EVEN FASTER storage solution via the Thunderbolt port.
    BMan - Reply
    Be wary of saying that thunderbolt will be faster than apple's internal disk speed. Because most thunderbolt cases have a PCIe 2.0 for each drive slot. You only start to get faster than the internal speed once you start striping drives. A PCIe 2.0 lane is about 500 MB/s with 20% taken for thunderbolt parity. My new 2TB EVO only gets about 370MB/s RW while my old RAID0 set of 2 junky drives gets about 660MB/s to 700MB/s
    Ryan Ragle -
    I plan to replace my ssd to samsung 950.
    nuieskater -
    Would very much like to know: Can the stand be unscrewed and removed after disassembly? I see there are 3 screws on each side of the internal spring attachment but even if these are removed it is unclear to me if the stand can then be detached from the large metal backing if the screws / springs are removed. Does it appear as though it can be removed?
    sean2078 - Reply
    Yes it can be detached easily. but be careful its a long sensitive work to reach there and back.
    Babak -
47 Comments
This site is way cool! Is it easy to upgrade the CPU once inside?
Matt - Reply
Absolutely! Same procedure as last year's model: iMac Intel 27" EMC 2639 CPU Replacement.
Looks like you can upgrade to a new cpu (Haswell refresh probably) since it doesn't appear to be soldiered on
Daniel - Reply
Thats unlikely, it depends on the mobo, i have not heard any confirmations of this so far.
adriandatriguiran -
Any idea what the part number is for the 8GB modules? This shows 4x2GB which is the standard. I ordered that memory configuration, expecting I can source new 8GB modules for less than Apple's price.
timothyweaver - Reply
looks like 9to5mac found your answer http://9to5mac.com/2014/10/17/retina-ima...
Daniel -
Any plans to sell that groovy wedge from Step 4?
wisacks - Reply
Why didn't you click the link?
iMac Opening Wheel
PhilBoogie -
That's not wedge-shaped at all! Did find the wedge in question here.
wisacks -
I am wondering about the storage configs because there is a slot for a SSD and a hard drive so if I only get the SSD option from apple does that leave the HDD slot free for me to put something along the lines of a 6TB hard drive in there?
Friedrich Winkler - Reply
I'd also love to know the answer to this question!
Tim Camber -
Just got mine with an SSD, while I didn't tear it down, it's listed as SATA APPLE SSD SM0256F.
ZMonty -
This is also my thought. The Fusion drive is a HDD and a 128GB SSD, so would getting a 512GB SSD iMac and then adding your own HDD have the same effect. This question needs answering!
RaviJ -
the HDD area will be empty but will also be missing the cable, so you'll need to get the cable if you want to add a hard drive.
lucasgodfrey -
if directly buying a ssd without fusion drive (and larger than the basic 128gb given with fusion drive) can I add a hdd after and make a larger and better (and cheaper) fusion drive myself or will the hdd slot inoperating
jo sevb - Reply
Do you know if there's a SATA and SATA-Power cable included in the non-fusiondrive therefore SSD only configuration of the iMac?
(based on the question above)
mahatmafatal - Reply
There is NO power/SATA cable supporting the 3.5" bay included in the SSD only version of the iMac Retina - you will only get the cable if you order the Fusion drive. iFixIt does not mention this and neither does OWC. I found out the hard way.
If you want to add an internal SSD you will have to source the Apple cable - I have yet to find it. If anyone can point me in the right direction it would be much appreciated!
The open power/SATA ports are facing the back of the machine and require 90% disassembly to access - as per iFixIt's guide.
The other issue could be that Apple reads the HD temperature from the drives they support - no support means that the iMac fans will run at 100% all the time. As far as I can tell, you can either run an app that overrides fan control or you can buy an OWC cable that fools the system - I believe that it merely short pins 2 and 7 to turn off this feature.
I moved from an older Mac Pro to the new iMac Retina and I am not a happy camper.
digitaljustin -
Can we imagine replace the display of iMac late 2013 (i7 GTX 780M Fusion Drive) with the retina 5k display ?
yannick - Reply
No, the displays are not compatible. The Retina 5K display has a different data cable.
im guessin about 2200 dollars profit on each unit
bellsouth1972 - Reply
Awesome job like always.
I do have a question, where does the hot air goes, after is moved by that fan?
I ask, because I don't see any vents.
GrTitan n - Reply
You can see the exhaust vent in the 2nd picture of step 3: iMac Intel 27" Retina 5K Display Teardown
It's located directly above the RAM access door.
Maybe I'm missing something - I've not had an iMac since the first Intel version was released in 2006 - but can I replace the Fusion drive with my own 1TB SSD?
cbd2dbc - Reply
Is there any change in the hinge mechanism ?
Specially the two circle plastic washers that place center of it ... like any material change or design improvement ?
Amir - Reply
I understand from other forums it's possible to disable the fusion drive setup via terminal commands. If you were to replace the stand 1TB hard drive with 1TB SSD, is it possible to then install OSX & Apps on the 1TB SSD and avoid having to use the SanDisk PCIe SSD ?
Also if you opt to purchase the iMac with flash storage only, flash storage would imply ssd rather PCIe SSD ?
ekynox - Reply
Any explanation why the fan in the 5K iMac is oh so much louder than in the predecessor? I don't think I have ever heard the fan in the December 2012 27", but the one in my 5K blows as soon as even a hint of a workload is required.
phototrek - Reply
Hi, is the RAM identical to the one found in late-2013 iMac? The Apple's website seems to indicate it is the same 1600 MHz RAM, but I need to know it is, thanks!
petarkg - Reply
There are many issue being reported with the hinge failing on the older iMac (2013), the culprit being two small plastic washers breaking which results in the screen flopping forward.
I would really like to know if this design has changed for the newer iMac model.
Jaybe - Reply
I want to install a modified, (shortened), stand. It appears that the stand can not be removed as was possible with the original iMac using a credit card to unlock the mechanism. Is this correct? If so then the only way to remove the stand is to open the iMac up? If so, shame on Apple!
Paul Yarnall - Reply
I'm start to getting worried about repairing because it's hard to do so and I am aware that I could break or damage internal modules unnoticed. There're hardly to find mac professional in my country except in apple store which they're not support to upgrade anything.
Mr. Hymn - Reply
He 27" iMac had a lot of issues related to cooling leading to frequent burn outs of the graphics card (2011-2012). Do you have any comments on that wrt the new 5K iMac. I can see they changed the exhaust slots, etc.
shantanughosh - Reply
I'm about to order a late 2015 27" with 512gb "Flash".
• Since there will be no HDD installed by Apple will there still be everything I need to install my own?
• If this is the case is there any reason why this drive couldn't be an SSD?
• 2.5" or 3.5"?
Tony Visconti - Reply
I have this same question on a late 2015 iMac 5K with an 256 internal flash disk. Right now, I have an additional external Samsung 1Tb SSD which I placed in a standard USB3 housing but it would be cool if it could go internally. If you find anything, I'd be glad to share.
Jacky
Jacky Bendayan -
hi guys tonight I did take out the flash drive and 3TB HDD out of the iMac and installed 1TB SSD instead now I am installing the OS by the Command +R. Everything looks fine. I searched everywhere but no one did this. Thought you guys may wanna know that.
Babak - Reply
I can't believe I even started reading this nonsense. What on earth does more pixels have to do with repairability? I think you people try too hard, seriously. The whole "review" business has turned into a huge joke. Oh look! A backplate! And this over here.. A PCIe SATA, not surprisingly something that they've used in a different model because WHY THE F*@K NOT?! Terrible. Absolutely terrible. Do you have to pretend to be a inane moron to write reviews or does it only help?
Oi - Reply
I have a late 2014 iMac 5K Retina with 32gb Memory. Is it possible and feasible to replace the CPU with a 2015 as as to increase the Memory?
Jason B - Reply
How hard would it be to change the iMac to a VESA compatible one instead of using the stand attached to most of them? You can't do this easily I am sure.
Taylor Harris - Reply
there is a lot of reference to older version of the same model. every teardown should be independent. i still have no idea what the two huge plastic parts on left and right are. I guess its sound but really that large?
eckndu - Reply
Can I replace the GPU
muberuka justus - Reply
My headphone jack broke.
Is it part of the logic board, or a part connected to the logic board?
It broke within the 2 year warranty, will Apple repair it?
Spunkie - Reply
Beautiful explanation, charting, and breakdown!
transattic - Reply
all iMac 27 5K Late 2015 with PCIe SSD installed for default have a SATA port free?
Nicola Albano - Reply
2019 iMac 27" 5K Backlight Cable replacement?
Pedro Montes - Reply
Can you replace the glass panel without replacing the internal screen? My glass is cracked but otherwise, the monitor and everything else looks and works just fine.
Melinda Rivers - Reply
Is the iMac’s built-in power cable receptacle removable in these models? I have completely gutted my 2015 5K and I can’t see any obvious way to remove it.
Zane Parkinson - Reply
I am impressed with the quality of this published event and its relevancy for today! Well done Sam and team!
Deeno - Reply
Past 24 Hours: 37
Past 7 Days: 236
Past 30 Days: 1,098
All Time: 649,679
