This teardown is in progress – Reload periodically to see the latest changes!
  1. iPhone dock Teardown, Getting started: step 1, image 1 of 2 iPhone dock Teardown, Getting started: step 1, image 2 of 2
    • Start by flipping the dock upside down.
  2. iPhone dock Teardown, Removing the back: step 2, image 1 of 2 iPhone dock Teardown, Removing the back: step 2, image 2 of 2
    Tool used on this step:
    Jimmy
    $7.95
    Buy
    • Take your Jimmy and push it in between the bottom cover and the body. Push down to lift the bottom cover.
  3. iPhone dock Teardown, Getting the back off: step 3, image 1 of 2 iPhone dock Teardown, Getting the back off: step 3, image 2 of 2
    • Carefully remove the clips on the side by pushing up with the Jimmy. If needed, use the plastic Opening Picks to keep the back piece from popping back into place.
  4. iPhone dock Teardown, Looking at the dock: step 4, image 1 of 1
    • Remove the dock completely from the plastic frame.
  5. iPhone dock Teardown, Peeling back the black sticker: step 5, image 1 of 3 iPhone dock Teardown, Peeling back the black sticker: step 5, image 2 of 3 iPhone dock Teardown, Peeling back the black sticker: step 5, image 3 of 3
    • The silver adhesive is covering two Phillips screws at opposite ends of the dock. Peel back the adhesive on these areas and remove both screws.
  6. iPhone dock Teardown, Removing four Phillips 000 screws: step 6, image 1 of 1
    • Remove the back plate once the screws are out.
    • Remove four Phillips #000 screws surrounding the Lightning connector.
  7. iPhone dock Teardown, Removing the Lightning connector: step 7, image 1 of 2 iPhone dock Teardown, Removing the Lightning connector: step 7, image 2 of 2
    • A similar adhesive can be found covering the plug for the Lightning connector. Peel the adhesive back and gently lift the cable to disconnect the connector.
Nathan
386 Reputation
2 Guides authored
One Comment
is it possible to find the lighting connector, since I have one that fell and it got all twisted and damaged and it tore the connector
Uriel Ramos - Reply
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 10
All Time: 2,139
