Acer Chromebook Won't Turn On
Jacob Mehnert and 4 contributors
Last updated on
Often, it is easy to forget the troubleshooting basics during times of frustration. Before attempting any significant repairs for your device, check the following. TESTING
  • Ensure your Chromebook's charging cable is correctly seated in the charging port. If you have depleted the battery and are attempting to charge the device, ensure the charger is securely connected to the charging port and plugged into a functioning power source. A complete circuit must be established between the charger, the Chromebook, and the power source to enable proper charging.
  • Ensure that the power source your charger is plugged into is powered on. It is possible to overlook a non-functioning power source. Try plugging your Chromebook into a different power source to avoid any issues.
  • Verify your charging cable is not damaged. Inspect the charging cable for any visible signs of damage or frayed wires. If you detect any damage, consider using a different line or replacing the current one.
  • Verify your device's charging indicator light is functioning correctly. When connected to power, see if the charging indicator LED illuminates or changes color, indicating the charging status of your Chromebook.
  • Attempt a hard reset of your Chromebook. Press and hold the power button for at least 10 seconds to discharge any built-up power and possibly resolve software glitches. Then, try powering on your Chromebook again.
  • Ensure your charging port is clean. Dust or debris can sometimes accumulate in the charging port, preventing the proper connection. Use a soft brush or compressed air to clean the charging port gently.
If the issue persists, proceed to the more in-depth tips below.
Causes
2
Sometimes, it's not the Chromebook but the malfunctioning display. Check with an external monitor to see if the Chromebook is working but not displaying anything.
If your Chromebook is on, but the screen remains dark, check out our Acer Chromebook Black Screen page instead.
4
Suppose your Acer Chromebook displays a black screen even after following the troubleshooting steps mentioned earlier. In that case, there is a high likelihood of a problem with the motherboard or the surrounding components.
  1. Remove any accumulated dust or debris from inside the device for proper airflow.
  2. Ensure that your device's CPU is adequately cooled. Specific Acer Chromebook models, such as the C712 Series, have encountered cooling fan failure caused by disconnected ribbon cables. If you have recently reinstalled your heatsink, double-check that wires are securely attached and that thermal paste has been appropriately applied.
  3. Reset your device's BIOS Settings by uninstalling and reinstalling the CMOS battery. This clears any potential conflicts or misconfigurations.
  4. Verify that the RAM module is installed correctly and functioning properly. If the RAM module is not properly seated, try reinserting or replacing the module.
  5. Perform a thorough visual inspection of the motherboard for any signs of burns or damaged components. If you observe any visible damage, such as burns or parts that appear to be physically damaged, the motherboard likely needs to be replaced.
View statistics:
Past 24 Hours:
5
Past 7 Days:
44
Past 30 Days:
203
All Time:
2,278
