You're seeing solutions for Bosch Dishwasher. Select your model to find parts for your device.
Introduction
The E24 error code on Bosch dishwashers means that the dishwasher is not draining properly due to the drain filter being blocked. Below are the troubleshooting tips that will correct this error code.
Additionally, don't forget to perform regular dishwasher maintenance.
Causes
Error code E24 likely indicates water buildup underneath the machine. In some cases, this error may be caused by control board issues. Perform a hard reset:
- Disconnect the power to the dishwasher for five minutes.
- If the error code returns, continue troubleshooting on this page.
There are other options for testing whether E24 is a board glitch.
- Press start, then hold the start button down for several seconds. This should reset the dishwasher and start a self-draining cycle. If your dishwasher begins draining, this is a good sign. This suggests that the error code isn't related to draining.
- If your dishwasher throws the code about two minutes into the wash cycle, open the door and press start, then close the door before the error trips.
- Or, open the dishwasher after a minute, hit start, then close the door again.
- In other cases, simply open and close the door.
- This is often a workaround for the error code and suggests a faulty control board. You can delay the replacement of a board with this trick.
Note: If your dishwasher isn't draining, then do not attempt to override the error code. Continue troubleshooting and checking your drainage system based on the dishwasher not draining wiki.
Applicable Models
Some of the afflicted models are listed below, and you can use CMD-F or CTRL-F to check your serial number. This list is not exhaustive, and your model may not be listed.
GM926710, SHE43P25UC/64, SHE45M05UC/50, SHE45M05UC/50, SHE45M06UC/50, SHE45M06UC/50, SHE4AP06UC/06, SHE4AP06UC/06, SHE55M12UC/64, SHE55M15UC/64, SHE55M16UC/64, SHE55M16UC/64, SHE58C05UC/48, SHI4302, SHI4306, SHI6802, SHI6805, SHI6806, SHU9915UC/11, SHX43C05UC/46, SHX45M05UC/50
Additional Resources
- Contact Bosch Customer Support at 1-800-944-2904
- Reset Bosch Dishwasher
