Dell Inspiron Series Troubleshooting: Fix Common Problems
The first step towards a working Dell Inspiron Series is identifying the problem. Select one of our preferred guides below to diagnose and solve Dell Inspiron Series common issues.
Dell Inspiron Won't Turn On
If your Dell Inspiron will not turn on, this page aims to help you identify the causes and what to do to fix them.
Dell Inspiron Battery Draining Fast
If your Dell Inspiron battery is draining fast, this page aims to help you identify the causes and what to do to fix them.
Dell Inspiron Keyboard Not Working
If your Dell Inspiron keyboard is not working, this page aims to help you identify the causes and what to do to fix them.
Dell Inspiron Black Screen
Does your Dell Inspiron have a black screen? This problem page will go over several common occurrences when it comes to a Dell Inspiron screen not turning on. The problem can be caused by either software or hardware causes, so read on to determine the right solution for you!
Dell Inspiron Not Charging
If your Dell Inspiron is not charging, this page aims to help you identify the causes and what to do to fix them.
Related Dell Laptop Problems
Dell Laptop Not Charging
If your Dell laptop is not charging, this page aims to help you identify the causes and what to do to fix them.
Dell Laptop Keyboard Not Working
If your Dell laptop keyboard is not working, this page aims to help you identify the causes and what to do to fix them.
Dell Laptop Battery Draining Fast
If your Dell laptop battery is draining fast, this page aims to help you identify the causes and what to do to fix them.
Dell Laptop Won't Turn On
If your Dell laptop won't turn on, isn't starting, or gets hung up on a startup screen, this page aims to help you identify the causes and how to fix them.
Dell Laptop Frozen
Is your laptop locking up or freezing? Are apps becoming non-responsive? Is your laptop stuck on the lock screen? Keep reading for some fixes!
Dell Laptop Keeps Restarting
Is your Dell laptop rebooting randomly or restarting over and over? Are you stuck in a boot loop and can't get out? Have a look at these solutions.
Dell Laptop Running Slow
Is your Dell laptop struggling with simple tasks? Is it running as slow as molasses? Are apps non responsive, or your cursor keeps spinning? Try these tips to top out your speed!
Dell Laptop Blue Screen
Is your Dell laptop crashing to a Blue Screen? Are you getting random restarts followed by a blue error message? This will need some detective work, but is definitely fixable!
Dell Laptop Black Screen
Does your Dell laptop have a black screen? Are you unable to get anything on your display? Can you only see black aside from a cursor? Have a look at these fixes!
Dell Laptop Overheating
Is your Dell laptop getting too hot? Is it uncomfortable to sit with your laptop in your lap? Is your fan spinning at full speed all the time? These fixes will cool you off in no time!
Didn't see your problem? The iFixit Community has answers.
Browse the most common questions asked by our members to see more solutions. Still no luck? You can always ask for help!
Laptop not booting, fan spin for a few seconds then stops...
Dell Inspiron 15 (1545)
How do I bypass the password authentification system?
Laptop not switching on but caps lock lights up why?
Dell Inspiron 15 3567
Won't power on, light blinking 3 amber, 1 white, bad coin cell battery
Dell Inspiron 15-3593
Add Boot Option using Insydeh20 setup utility
Operating System loader has no signature. Incompatible with secure boo
Dell Inspiron 15-5559
Won't turn on even when plugged in
Dell Inspiron 15 (1564)
Battery light flashing amber
Dell Inspiron 1420
