PlayStation 4 Controller Won't Turn On
Maaz Hussaini and 3 contributors
Last updated on
Warning!
If your device is swollen, bulging, overheating, or smoking, DO NOT PLUG IT IN! The battery is almost certainly the cause and should be replaced. You can find a replacement guide and DualShock 4 CUH-ZCT2 Batteries for your controller at iFixit. Whatever you do, please be sure to dispose of your battery properly.
  • Power Cycle the Controller: Hold the PlayStation button to turn off the controller and then turn it back on. Sometimes, a simple power cycle can resolve minor issues.
  • Make sure the controller is charged. If it does not show any signs of life, try charging it for 15 minutes. Look for any indication that the controller is charging (e.g., lights on the controller).
  • Try plugging the controller into the console. Attempt to use your controller while it is plugged into your console. Often, this can indicate an issue with the controller hardware and helps us determine if the controller is experiencing an issue with the internal battery.
Causes
If re-syncing the controller with the system didn't work, you can manually reset the controller:
  1. Locate the small reset button on the back of the DS4 near the L2 button.
  2. Push the button with a small, pointy object, such as an unfolded paper clip (or a similar object). The button is in a tiny hole next to the top right screw on the bottom outer shell.
  3. Hold the button down for several seconds, and release.
In addition, updating your controller firmware can also resolve many different issues.
  1. Connect the controller to the PS4 using a USB cable.
  2. Go to Settings > Devices > Controllers > Update System Software.
  3. If there is an update available, then you should update. This will resolve temporary issues with your controller's software and help your controller with issues turning on.
2
If you cannot resolve the issue by updating your controller's firmware, the issue might be caused by your controller's physical hardware.
View statistics:
Past 24 Hours:
15
Past 7 Days:
94
Past 30 Days:
502
All Time:
2,289
