Introduction
Does your Insignia NS-24ER310NA17 television no longer turn on or show any signs of life? Insignia NS-24ER310NA17 TVs are susceptible to a range of problems that can cause them to stop turning on. Check the following possible causes to identify and solve the problem.
If your television is lighting up or making any kind of noise but is not showing a picture, see the Insignia NS-24ER310NA17 Picture Does Not Appear problem page for possible causes and solutions.
Causes
If you have tried the above solutions and the television still does not turn on, it may be plugged into a faulty power outlet. Unplug the television from its power outlet. Then, plug in something like a working lamp to the television’s power outlet to check if the outlet is working properly. If the lamp does not turn on when plugged into the television’s power outlet, try plugging the TV into another power outlet.
If the power source is working, try a power reset, next. To perform a power reset, unplug the set from the outlet. Then proceed to hold down the power button for one minute. Release the power button, plug the TV back into the outlet, and attempt to power it on. If the TV turns on, it is likely that a power supply replacement may become necessary in the near future.
If you have tried the above solutions and the television still refuses to turn on, there may be a problem with the TV’s motherboard. See the Insignia NS-24ER310NA17 Motherboard Replacement Guide to replace the television’s faulty motherboard.
- 10 minutesModerate
Questions other people have asked about this
- Why is my tv not coming on
- Why won't Sony Bravia, Model KDL-32L4000 power up/turn on?
- Sony Bravia KDF50E-2010 50" LCD HD TV won't power on?
- What do I check if my Sansui TV Model SLED2490 will not turn on?
- Why won't the screen on my Vizio VO37L television power on?
- Teac TV won't turn on
- Why did my tv quit working?
