JBL Charge 3 Ports Don’t Work
Arielle Sampson and 2 contributors
Last updated on
Do your JBL Charge 3 speaker’s ports no longer work? Does either charging your device, using the device as a charger, or using an audio cable not work? JBL Charge 3 speakers are susceptible to a range of problems that could cause the speaker’s port to stop working. Check the following possible causes to identify and solve the problem.
Causes
If your JBL Charge 3 speaker is not charging, you cannot use the device as a charger, or the audio cable function does not work, the problem could be the cable itself. Check that any cable you are attempting to use works with another device. Also, try using a different cable with your speaker, and see if the problem persists.
2
If the cables are not at fault, the ports may be to blame. If one of the three ports will not work with its functioning cable, see the JBL Charge 3 Port Bay Replacement guide to replace the ports.
View statistics:
Past 24 Hours:
0
Past 7 Days:
7
Past 30 Days:
18
All Time:
1,445
