You're seeing solutions for Kenmore Dryer. Select your model to find parts for your device.
Introduction
Modern dryers have digital displays which convey error messages when parts fail or something is simply not right. Older dryers may not have digital displays and instead use a series of LEDs to signal that a component isn't working correctly. Diagnose your code below.
First Steps
Before undertaking any of the more time consuming solutions below, these are a few fundamentals to get you started.
- Make sure there is power at the wall outlet.
- Check if a household fuse is blown or if a circuit breaker tripped
- Check that the dryer vent is properly installed and clear of lint or obstructions.
- Check all connections before replacing components. Look for broken or loose wires, failed terminals, or wires not pressed into connectors far enough.
- A potential cause of a control not functioning is corrosion on connections. Observe connections and check for continuity with an ohmmeter.
- Connectors: Look at the top of the connector. Check for broken or loose wires. Check for wires not pressed into the connector far enough to engage metal barbs.
- Resistance checks must be made with dryer unplugged or power disconnected.
Causes
Haven't found the solution to your problem?Browse our forum
