Keurig K-Duo Repair Troubleshooting: Fix Common Problems
The first step towards a working Keurig K-Duo Repair is identifying the problem. Select one of our preferred guides below to diagnose and solve Keurig K-Duo Repair common issues.
Keurig K-Duo Does Not Turn On
Pressing the power button on your Keurig K-Duo does not turn it on.
Keurig K-Duo Not Brewing an Entire Pot of Coffee
Keurig K-Duo is brewing coffee into the pot, but not enough. An insufficient amount is coming out.
Keurig K-Duo Coffee or Water Does Not Reach Target Temperature
When running a “cleansing brew” or pressing the carafe button the hot plate will not heat up. Coffee or water will not heat up when the machine is running.
Didn't see your problem? The iFixit Community has answers.
Browse the most common questions asked by our members to see more solutions. Still no luck? You can always ask for help!
Unit turns on but not brewing coffee.
Keurig K-Duo Repair
We get error messages on the pod side
Keurig K-Duo Repair
Dispensing 12oz EACH TIME-Regardless of choice
Keurig K-Duo Repair
Intermittent power switch needs replacing
Keurig K-Duo Repair
As the maker gets older why does machine trip the 20 amp breaker
Keurig K-Duo Repair
