LG Front Load Washing Machine Troubleshooting: Fix Common Problems
The first step towards a working LG Front Load Washing Machine is identifying the problem. Select one of our preferred guides below to diagnose and solve LG Front Load Washing Machine common issues.
LG Front Load Washing Machine Leaking
Your LG Washer is leaving puddles. You need to get it to stop. Let's walk through some causes and solutions.
LG Front Load Washing Machine Not Spinning
Your LG front load washer isn't going into the spin cycle. Clothes are staying too wet. Let's look at causes and solutions.
LG Front Load Washing Machine Has No Water
Your LG front load washing machine is filling with water slowly or not at all. Here are some things to check so you can fix it. You can do this!
LG Front Load Washing Machine Not Draining
Your LG front load washing machine doesn't pump out the water. Let's look at some causes and solutions! They are pretty straightforward.
Related LG Washing Machine Problems
LG Washer UE Code
Your washer is showing a code, either UE or maybe uE. It is having trouble (it thinks) balancing the load. Not to worry; lots of things to try and to check! Let's dive in!
Related Washing Machine Problems
Your washing machine is only getting half the job done. It isn't spinning and the clothes are still wet. The cycle isn't complete. Perhaps the spin cycle isn't really doing its job; it spins but slower. Maybe you have to run it twice. We will look at the possible causes and solutions.
Washing Machine Shaking
In the spin cycle, does your washing machine sound like it's going to shake and bang itself apart? Let's get that machine settled down. Here are some possible fixes.
Your washing machine is full of water but at the wrong time. Let's get you emptied out and going again.
Washing Machine Won't Turn On
Your washing machine won't start. You press the right button, turn the knob or pull the knob out, but nothing or nothing much. Amazingly there are a lot of fixes that are simple and straightforward. Also, you don't even have to dig into the machine to get going. Let's start with the simple solutions.
Your washing machine has no water to wash the clothes, it will not fill. You turn it on but no water comes in. Maybe the water comes in really slowly. Or maybe it's only just the cold or hot water that flows. What can you do? There are a whole bunch of things to check. Let's go see a solution.
Experiencing issues with your washing machine can be inconvenient, but many common problems can be quickly resolved through basic troubleshooting. This guide aims to assist you in identifying and fixing prevalent washing machine issues from the comfort of your home.
Washing Machine Is Leaking
Your washing machine isn't holding its water. It's leaking all over the floor. Puddles are forming. You need to track down why. We can walk through the causes of a leaking washer.
Washing Machine Door Is Locked
Your Washing Machine door is locked and your clothes are stranded inside. This page is meant to help you find a way in, and find out what went wrong. Then we will look at some solutions, once we know what went wrong. Don't despair, you can repair! Most of the issues are centered around failures in the door locking mechanism which is a straightforward fix. Some issues are encountered with defective control parts; in a few cases, these can be caused by the latch failing as well.
Didn't see your problem? The iFixit Community has answers.
Browse the most common questions asked by our members to see more solutions. Still no luck? You can always ask for help!
LG wm2016cw Front Load giving OE error code
LG WM3050CW
Washer not powering up
LG WM3050CW
Inlet to dispenser connection
LG WM3050CW
