Microsoft Tablet Troubleshooting: Fix Common Problems
The first step towards a working Microsoft Tablet is identifying the problem. Select one of our preferred guides below to diagnose and solve Microsoft Tablet common issues.
Microsoft Surface Tablet Black Screen
Is your Surface on, but you can't see anything on screen? Can you log in, but you only get a cursor and nothing else? Have a look at these solutions!
Microsoft Surface Tablet Overheating
Is your Surface tablet getting too warm to touch? Are you getting warnings or a thermometer icon onscreen? Have a look at these solutions!
Microsoft Surface Tablet Not Charging
Is your Surface refusing to charge? Is it giving a Slow Charge warning? Does the battery drain even when you're connected to power? Give these fixes a try!
Microsoft Surface Tablet Will Not Turn On
Is your Surface Tablet failing to turn on? Are you getting a blank screen with no signs of life? Keep reading for some typical fixes!
Didn't see your problem? The iFixit Community has answers.
Browse the most common questions asked by our members to see more solutions. Still no luck? You can always ask for help!
How do I identify my specific model of Surface Pro?
Microsoft Surface Pro
Can I increase Surface PRO RAM
My fully charged surface pro 2 won't turn on again
Microsoft Surface Pro 2
What temperature does the glue need to be heated to?
Microsoft Surface Pro 3
What is the suggested temperature of a heat gun to remove the screen?
Microsoft Surface Pro 4
Grinding / Buzzing Fan
Error message: "Couldn't find bootable..." but SSD and OP system is OK
Microsoft Surface Pro 7+
Can the hard drive be replaced?
