Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Rice Cooker won't turn on
After plugging in the device, there are no signs of power
Tripped GFCI (Ground Fault Circuit Interrupter) power outlet
Before opening the device, be sure that the power outlet is working. If not, look around to see if there is a receptacle, common in kitchens and bathrooms, that has been tripped. If this is the case, then simply press the reset button
Faulty Power Cord
If the power cable shows visual damage, reference the power cord replacement guide
Aroma ARC-914SBD Power Cord Replacement
Faulty Control Module
If the power outlet and the power cord are working properly, there may be issues with the control module. Please follow the instructions set forth in the replacement guide
Aroma ARC-914SBD Control Module Replacement
Device doesn't become hot when on
After you plug in the device and press the Cook button, the device does not generate heat
Delay Timer is still active
Check to see if the cooking light is on, perhaps the delay timer is still on
Faulty Heater
If the problem isn't the delay timer, then it has to be an error with the heater.
Please reference the heating element replacement guide
Aroma ARC-914SBD Heating Element/ Thermostat Replacement
Device is dripping on the counter
During cooking there is a noticeable spilling of water on the counter
Condensation Catcher is full or missing
Check the condensation catcher located on the right of the device. If it is full, simply empty the container. If damaged or missing, refer to the condensation trap replacement guide
Aroma ARC-914SBD Condensation Catcher Replacement
Buttons are unresponsive
After pushing a button, the intended effect does not occur
Sticky or Faulty Buttons
If some button(s) seems to not function properly, then the button(s) will have to be replaced. Refer to the push-button replacement guide
Aroma ARC-914SBD Push Buttons Replacement
Display not lit
The red light display is no longer lit and you can no longer see what you wish to select
Faulty LED lights
If the device functions normally but the LED lights do not turn on, they need to be replaced. Refer to the LED replacement guide
4 Comments
I purchased an Aroma Rice cooker about 5 years ago at Walmart. I loved so much I checked on Amazon to order a stand by for when I wore it out. I ordered on in July 2021. In December 2022 as I suspected my original quit working. So I pulled out the extra I purchased. When I did, just to be safe, I ordered another one. I used it once, and it will no longer turn on. So I pulled out the most recent one delivered this month. I used it once and IT won’t work. HELP! They should work more than once!!!!
Karen - Reply
Everything works on my aroma rice cooker but there is no heating
Trevor mills - Reply
My aroma rice cooker lights up but it not heating up what is the problem
I went thru 3 rice cookers ans used them no more than 2 times and they stop working. Nothing but junk.
Mike - Reply
