Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Laptop Will Not Turn On
Laptop will not activate when Power button is pressed.
Malfunctioning Battery
Plug the laptop's charger into the laptop. If the laptop is only able to turn on when it is plugged in, then the battery is the problem and will need a replacement.
Malfunctioning Charger
Plug the laptop's charger into the laptop. If the laptop is unable to turn on and the charging light does not light up either, then the charger is the problem and will need a replacement.
Keyboard Will Not Respond
Keys will not work when pressed.
Driver Malfunction
If the keyboard is not responding at all. Restart the laptop and run a diagnostic to the BIOS. THe keyboard driver may need to be reinstalled.
Stuck keys
If a key won't budge when pushed down, then there may be something lodged underneath the key. Remove the key and check underneath; if no obstructions are visible, consider wiping the area down before reattaching the key.
Device is Overheating
The laptop is running abnormally hot and/or is prone to shutting down without warning.
Prolonged use of the laptop
Using your laptop for a long period of time will cause your laptop to overheat. This can lead to damage of the battery. Best solution would be to use it for a shorter amount of time and take breaks.
Broken fan
If your laptop continues to overheat after you started to use it for shorter periods of time then your fan is broken and will need replacement.
Screen is Not Displaying
The computer seems to be on, but nothing is being displayed on the screen.
Low Brightness
If you can't see anything on your screen, your brightness setting may be too low. All you have to do is turn it up, which you can do with the function F5 key
Loose Wiring
It may be that the wire connecting the monitor to the rest of the computer has come loose from violent movement, or just not completely plugged in in the first place. To fix this you will have to disassemble your laptop most of the way, as the wire connecting the monitor rest under the keyboard.
Damaged screen
Your screen may just be damaged and need replacing all together. You will have to purchase a new one and replace the old one with it, disassembling the laptop most of the way.
1 Comment
Screen was working fine till I restarted the computer. Now the screen lights up but, nothing is displayed. I plugged in a monitor and it worked just fine. It has been stored away for about 6 months.
Larry Fairchild - Reply Share
