Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Overheating: ==
The system presents issues when turning on, during the boot up process, the system shuts down automatically after a minute or two. We’ve also discovered that during this process, there is no sound generation, therefore, meaning that the fan is not working properly.
Replace the heatsink/fan:
1) After shutting down the computer, disconnect all of the cords and wires. Remove any CDs or USB drives that may be present. 2) Using the suggested technique and the appropriate tools, open the computer casing. 3) Now, using your hands, try to rotate the fan to make sure it's not stuck. 4) Look into the fan and check for significant signs of wear and tear. 5) Plug it in again and verify that the fan is operating properly. 6) It is advisable to completely replace it if malfunctioning. Verify that the fan is the issue and not the wiring. 7) Change the fan for a better-speed, higher-quality model. 8) Additionally, examine all the fans that are connected to the GPU; if the GPU fan is not functioning, this may also result in thermal problems.
For more in-depth instructions on how to properly replace the heatsink/fan, please follow this link.
Battery Life Quickly Decreases:
The symptoms of a damaged battery are laptop battery dies sooner than it used to, laptop takes a long time to charge and the laptop unexpectedly dies. The cause of this is extremely high temperatures can cause lithium-ion batteries to deteriorate at an accelerated rate, which can permanently lower the battery capacity.
Replace the battery:
1) Start by turning off your laptop. Either press and hold the power button, or shut it down using the Windows start menu. 2) Unplug the AC adapter. 3)Turn the laptop upside down in order to remove the screws. Take note of where each screw belongs. 3) Detach the laptop bottom, and lift it slowly. Pay close attention since there could be cables or wires plugged into the laptop’s motherboard to the bottom panel. 4) Disconnect any cables attached to the bottom panel of your laptop. Make sure to not touch the motherboard or any internal computer board, a static discharge is capable of causing permanent damage to your computer. Touch something metal or wear a static wristband if available. 5) Locate the battery by looking for a long black strip towards the back of the laptop. 6) Start by checking if there are any screws holding the battery if needed, once confirmed that no screws are in place, begin unplugging the wires connecting the battery by gently lifting up on the port connected to the motherboard. 7) Proceed inserting the new battery after removing the old one and reattaching any screws as needed. 8) Use the connector to plug in the battery to the computer, the same way the old battery was attached. 9) If needed, reconnect any wires from the bottom panel back to the computer if they were removed during the replacement process. 10) Reattach the back panel into place and reattach all the corresponding screws. 11) Last, plug the AC adapter to allow the new battery to charge.
If your are experiencing any difficulties with the instructions given, feel free to follow this link for an in-depth solution.
Trackpad won’t respond:
Having visible physical damage, such as breaks, scratches, or a loose trackpad surface. Things that might cause the damaged trackpad to have physical damage is misapplication of cleaning materials using abrasive or strong cleaning materials might scratch or damage the surface of the trackpad.
Replace the trackpad:
- Safety First: Turn off your laptop completely and unplug it from the power source.
- Access the Trackpad: Depending on your Acer laptop model, you may need to remove the laptop's bottom cover, keyboard, or palm rest to access the trackpad.
- Remove the Old Trackpad: Locate the trackpad assembly inside the laptop. Carefully disconnect any ribbon cables or connectors that are attached to the trackpad. Use a screwdriver to remove any screws securing the trackpad to the laptop's chassis. Gently pry the old trackpad out of its housing, being cautious not to damage any surrounding components.
- Install the New Trackpad: Place the new trackpad into the same position where the old one was. Reattach any ribbon cables or connectors to the new trackpad. Secure the new trackpad in place with screws, if applicable.
- Test the Trackpad: Power on the Acer laptop and test the new trackpad to ensure it functions correctly. Check for responsiveness and accuracy.
- Install Drivers: Depending on your operating system and laptop model, you may need to install or update trackpad drivers.
- Final Check: Double-check all connections and screws to ensure everything is secure.
Please utilize this link for additional in-depth instructions.
The screen doesn't come on:
The symptoms of a damaged screen are blank or black screen, color fade, fuzzy, blurry, distorted and stretched image. The cause of these symptoms could relate to infection with viruses, using an outdated graphics card driver, having a drained system, or having faulty system files.
Display assembly:
1) Prepare your workspace and safety: Work on a clean, well-lit, and static-free surface.
2) Remove the Battery: if possible, remove the laptop's battery to ensure safety during the screen replacement
3) Remove the Bezels: Use a plastic spider or pry tool to carefully remove the plastic bezel around the screen. Start at one corner and gently work your way around. Be cautious not to damage the bezel or the screen.
4) Access the Screen Mounting Screws: Once the bezel is removed, you'll typically find screws securing the screen to the laptop's frame. Locate and remove these screws. Keep them organized for reassembly.
5) Disconnect Cables: Behind the screen, you'll find a video cable and possibly other cables connected to the back of the screen. Carefully disconnect these cables by gently pulling them apart
6) Remove the Old Screen: Carefully lift the old screen away from the laptop's frame. Be cautious not to damage the cables or surrounding components.
7) Install the New Screen: Place the new screen in the same position as the old one. Reconnect the video cable and any other cables you disconnected earlier.
8) Secure the New Screen: Reattach the screws that hold the new screen in place. Ensure they are snug but not overly tight to avoid damaging the screen or frame.
9) Reattach the Bezels: Carefully snap the plastic bezel back into place. Start at one corner and work your way around until it's securely attached.
10) Test the New Screen: Reconnect the laptop's battery (if removed) and power it on to test the new screen. Ensure that the display is working correctly and there are no issues with colors, brightness, or dead pixels.
11) Reassemble the Laptop: If the screen functions properly, turn off the laptop and proceed to reassemble the rest of the laptop, including reinstalling the battery
12) Final Check: Power on the laptop once more to confirm that everything is working as expected.
Remember to consult your laptop's service manual or documentation for specific instructions related to your model, as disassembly and replacement procedures can vary significantly between Acer laptop models. If you're unsure about any step, it's safer to seek professional assistance to avoid causing further damage to your laptop.
Please follow this link for more in-depth instructions on how to replace the screen.
No Sound:
The no sound symptom occurs when there is complete silence, which could indicate that the speakers or headphones are not correctly attached or are malfunctioning. In the system settings, the audio output device can be muted or disabled.
Replace the speakers:
- Locate and Disconnect the Old Speakers: Locate the old speakers inside the laptop. Typically, laptops have two speakers, one on each side. Carefully disconnect any ribbon cables or connectors attached to the speakers. Use a screwdriver to remove any screws securing the speakers in place.
- Remove the Old Speakers: Gently lift and remove the old speakers from their housing, being cautious not to damage any surrounding components.
- Install the New Speakers: Place the new speakers into the same position where the old ones were. Reattach any ribbon cables or connectors to the new speakers. Secure the new speakers in place with screws, if applicable.
- Reassemble the Laptop: Reassemble the laptop by reversing the steps you took to access the speakers. Replace the keyboard, palm rest, or bottom cover, if removed.
- Test the Speakers: Power on the Acer laptop and test the new speakers to ensure they function correctly. Play audio to check for sound quality.
- Install Audio Drivers: Depending on your operating system and laptop model, you may need to install or update audio drivers to ensure proper speaker functionality.
Please follow this link for common troubleshooting procedures. Once you have confirmed that the speakers or headphones aren't malfunctioning because of a damaged cable, or faulty connection, please follow this link and refer to the video on how to properly detach the speakers in order to apply the replacement.
0 Comments
