Anker Soundcore Life Q20 Not Charging
Olivia S and 2 contributors
Last updated on
If your Anker Soundcore Life Q20 headphones are not charging fully or properly, follow this guide.
Causes
The Anker Soundcore Life Q20 headphones may need to be reset if they are not charging correctly.
  • Delete the pairing history from your Bluetooth device.
  • On the headphones, press and hold the volume up button and power button simultaneously for 5 seconds.
  • The LED indicator should flash red three times.
2
If encountering problems with holding power or charging, the battery may be faulty. Follow the step-by-step directions in Anker Soundcore Life Q20 Battery Replacement to replace the battery.
3
The charging cord and block for the headphones may be faulty or broken.
  • Leave the headphones plugged in for 24 hours to see if they charge.
  • Test the charger with another device to ensure that the charger is working properly.
    • If you find that the cable or block of the charger are not working, try another charger. Soundcore recommends that you use a 5V charger.
4
If all other parts of the headphones are working properly, the electrical outlet may be faulty.
  • Use the same outlet to charge another device to ensure that it is working properly.
  • If the outlet does not charge other devices, try a different outlet.
View statistics:
Past 24 Hours:
4
Past 7 Days:
25
Past 30 Days:
91
All Time:
525
