Anker Soundcore Life Q20 Static
Aaron Best and 1 contributor
Last updated on
If static sound overlays when using the Anker Soundcore Life Q20 headphones, follow this guide for potential solutions to this issue.
Causes
An amount of pressure on the headphones may be creating a crackling sound. To fix this issue, hold the volume up button and the power button at the same time for 5 seconds until a red light blinks 3 times. The device should reset and solve the issue.
2
Sometimes other devices may interfere with your connection to the headphones and cause static. Minimize the presence of other devices that could potentially interfere with your connection. Check if other paired devices are nearby and affecting your connectivity.
3
Occasionally, a device may have some difficulty connecting properly. Test the headphones with another device. Check for updates or restart the source device. This can ensure the source of the issues don't lie with the headphones.
4
Ensure the headphones are free of all dirt or debris. Regularly clean the components with compressed air or a soft brush and store the headphones in a clean environment. Maintain a clean device to potentially prevent the crackling sounds.
5
Broken hinges may interfere with your headphones and create static. You can learn how to replace those Anker Soundcore Life Q20 Hinge Pin Replacement with this guide.
View statistics:
Past 24 Hours:
Past 7 Days:
19
Past 30 Days:
82
All Time:
509
