Table of Contents
Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Computer Freezes Up
The computer is slowing down and/or freezing up and the bottom feels very warm.
Location
Ensure the laptop is on a flat and hard surface. I recommend using the laptop on a cool flat surface or on a cooling pad.
Faulty Cooling System
If changing the usage location has no effect, consider the following:
If you hear the fans running and there is no change, consider upgrading the cooling system.
If you don't hear any fans when the computer is warm, consider replacing the fans.
Computer Shuts Down When Disconnected From Its Charger
The computer turns off shortly after being removed from the power source.
Faulty Charger
Ensure the charging light is on when plugged in and the charging port is clear of debris or dust. If the light is on and the port is clear, consider buying a new charging adapter.
Inconsistent Battery Life
If you are not getting consistent usage time away from the charger after a full charge, the battery may be damaged or at the end of its life cycle. Consider replacing the battery.
Frequent Crashing and Error Messages
Some symptoms include crashing while the computer is booting windows, receiving error messages when trying to perform file moving tasks, and/or file names being scrambled or disappearing completely.
Replace the hard drive
You may want to consider replacing the hard drive on your Asus G73JH-RBBX05
Keyboard malfunctions or keyboard is not responding
The keyboard on the laptop isn't functioning properly or responding well
Faulty keyboard
If the keyboard is continuously not functioning or takes a while to respond, you may want to consider replacing the keyboard.
Keys jamming
If you notice a certain key isn't functioning, check to see if it is jammed. If you notice a key is jammed, attempt to blow compressed air under the key to remove debris and your keyboard should begin to function properly.
Blue Screen of Death
If your computer screen just displays blue, you properly have the blue screen of death.
RAM failure
One of the causes of the blue screen of death is RAM failure. Consider replacing the RAM on your computer immediately.
Josh DeBest
390 Reputation
2 Guides authored
Cal Poly, Team 22-11, Maness Winter 2017 Member of Cal Poly, Team 22-11, Maness Winter 2017
CPSU-MANESS-W17S22G11
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 286
