Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Coffee maker will not turn on
The coffee maker does not respond when the power is switched on.
Device unplugged
Make sure the coffee maker is plugged into a working electrical outlet. Try to plug coffee maker into at least two separate outlets to make sure the power outlet is functioning correctly.
Damaged power cord
Visually look over the power cord to make sure there are no obvious breaks, cuts, or damage done to cord.
Circuit board malfunction
The KF 440 is equipped with a circuit board that controls the functions of the coffee maker. Visually look over the circuit board and see if there are any burnt or broken components.
Coffee maker turns on but will not brew coffee
The power switch is on (red light appears), but no coffee is produced.
Water reservoir is empty
Make sure the water reservoir is filled with water.
Coffee pot not correctly in place
The coffee pot needs to sit correctly and fully onto the hotplate for coffee to brew.
Faulty filter basket components
The filter basket has a spring and ball assembly, which allows coffee to flow into the pot and stops flow when the pot is removed. If this assembly is broken, the coffee maker will not brew correctly. Refer to the Braun Aromaster KF440 Filter Basket Replacement Guide.
Coffee maker will only brew water
The coffee maker only produces hot water.
Empty filter basket
Make sure coffee grounds are in the filter basket.
Coffee maker brews slowly
The coffee maker is producing coffee, but at a slower than average pace.
Coffee maker needs to be cleaned
In addition to coffee grounds, the coffeemaker can build up calcium and mineral deposits. The coffeemaker can be cleaned by running the coffee maker once with a water-vinegar solution (1:1) and another time with just water.
Coffee maker’s one-way inline valve is clogged
The KF 440 is equipped with a one-way valve to aid in brewing. This valve can become clogged with residues, causing the coffee maker to brew very slowly. Refer to the Braun Aromaster KF440 one-way valve Replacement
Brewed coffee is not hot
The coffee maker brews coffee normally, but the coffee from the carafe is not hot.
Automatic shut-off switch has been activated
The automatic shut off switch will turn the coffee maker off after a given amount of time for safety reasons. Most coffee makers default shut off time is 2 hours unless otherwise manually programmed for a different time.
Faulty heating element
The heating element, which heats the coffee to the desired temperature, can fail. This failure would cause the coffee maker to brew cold coffee. Refer to the Braun Aromaster KF440 Internal Tubing Replacement Guide
Coffee grounds appear in brewed coffee
There are coffee grounds in the bottom of the carafe.
Paper filter not properly seated
The paper filter needs to sit in the basket correctly for the brewing process. If the sides of the filter are folded over and not in contact with the filter basket, coffee grounds will leak through the basket and into the coffee pot. If this happens, clean the filter basket and coffee pot, then install a new filter that is correctly positioned.
Damaged filter basket
Visually check the filter basket for cracks or holes that could be allowing coffee grounds to leak into the coffee pot. If cracks or holes are detected refer to the KF 440 filter basket replacement guide.
Water appears around the base of the coffee maker
Water leaks beneath the coffee maker and on to the countertop.
Too much water in reservoir
Too much water can be poured into the coffee maker’s reservoir. This would cause water to leak out of coffee maker, leaving a puddle of water around it.
Internal hoses are cracked or Broken
The tubing inside of the coffee maker can become cracked or broken over time , causing the coffee maker to leak water . Refer to the Braun Aromaster KF440 Heating Element Replacemen
18 Comments
Someone brewed coffee in my pot without using a filter. Now it won't work. The company said it's unfixable. Any suggestions?
Rachel Gross - Reply
Do you still have it? Try to disassemble it to give it a thorough cleaning. Manufacturer just doesn’t want to help you because they just made a couple of dollars selling you the item and won’t make any by fixing it for you, but that doesn’t means it can’t be repaired. Coffee makers are simple machines that you can repair yourself until the electronics, pump or heating element burnt out.
Andrés Boza Arce -
Do I need to order a new circuit board. Or do I return it to where I bought it?
aaw7051 - Reply
Circuit boards for coffee makers are hard to find. You may inquire with the manufacturer. If still under warranty (and you kept the receipt) exchange for a different brand of coffee maker.
Andrés Boza Arce -
i pour water in turn switch to show “red” pot warms up even gets hot
but no coffee brews am i doing something wrong
buflobobbr - Reply
