Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Zoom Won't Focus
No matter what I do, the zoom won't focus to make clear pictures.
The camera isn't steady
Be sure that your hand or surface is steady, otherwise the camera will be unable to quickly focus on a frame. If the camera detects movement in your hand, its focus will constantly change.
It's too dark for your camera to create contrast
Relocate to an environment with more natural light or add artificial light to your current environment. If there isn’t enough light to capture, your camera will not be able to discern objects to focus on.
Your camera is detecting too much movement
Oftentimes the camera just needs a moment to focus and capture movement, but if it doesn’t focus after about 30 seconds, try and adjust your aim.
Your autofocus is not working
Cameras sometimes require calibration. Switch to manual focus, measure your distance, and make sure the lighting is adequate.
Pictures Won’t Transfer to Another Device
My pictures won’t download on my computer
The cable is loose
Problems like this can be resolved by just checking the connection, making sure the cord is in the right port and completely plugged in.
Your computer isn't compatible
Computers and cameras are sometimes not compatible with one another, depending on the file. Try another computer and see if you can send images from there onto your primary desktop or laptop.
Your auto power is switched on
Most cameras have an auto power feature which switches the device off when you’re not shooting. Switch this off so the connection is not broken when attempting to transfer images.
Camera Won’t Turn On
I’ve tried everything, but my camera isn’t powering up.
The battery is dead
Most of these problems can be solved just plugging in your battery to a charging station. If your camera is still not turning on, you may need to replace your battery due to age or corrosion. Replacements can usually be found online or through the store where your camera was purchased.
The circuit connector is broken
Sometimes, it could be something unrelated to the battery. It could be the circuit that connects the battery with the camera’s screen, lens, and flash. In this case, the circuit connector may need to be replaced.
The power button is broken
Parts can break. If you find that the battery is functional and there are no internal issues with your camera, the actual power button may be faulty or loose. Contact the manufacturer for information on replacement, repair, and warranties.
The battery terminal is dirty
If you have replaced or charged the battery and the camera still will not turn on, then clean the battery terminal with a dry cloth. After this is completed, then return the battery to the terminal.
The LCD Screen isn’t showing pictures
I’ve restarted the camera, but my images are still not appearing.
The screen is cracked or water damaged
First, assess your screen for physical signs of damage such as a crack, chip, or discoloration. If you notice any signs of this, your LCD screen will need to be replaced. Otherwise, consider that water getting into the device or dropping it could have damaged the images.
The wires that connect to the screen are faulty or disconnected
An LCD screen not displaying pictures could be the result of an internal issue such as wires becoming disconnected due to corrosion or dropping your camera. In this case, disassembly to fix the problem may be necessary.
The flash isn’t working
My flash won’t work even in the darkness
The flash isn’t turned on
While most cameras have an auto flash which senses the amount of light in the environment, there is usually a manual setting which can turn the flash on or off. Set your camera to auto flash or make sure the flash is switched on.
The bulb is burned out
Changing the bulb in a flash is usually a quick fix and bulbs can be bought at most office and electronic stores. See the guide for changing flash bulbs in cameras for user-friendly steps.
The wires between the battery source and flash may be disconnected
The flash not working could be caused by a faulty power line in your camera. Check your battery as mentioned above or your power source to determine if disassembly for repair may be required.
7 Comments
When taking a picture with my Cannon G12 everything looks normal on the screen but when you take the picture on the screen the image is there but it's white with lines through the picture. Would appreciate any advice on this problem.
Mona Timberlake - Reply
thats a sensor issue, you need a new sensor
Gus Hiddink -
the camera cannot record the picture taken.
when viewed only old pictures are visible
mnoor_mtahir - Reply
my G12 has purple hue to photo and on LCD with lines
mark - Reply
When I power my canon g12 powershot on it instanly takes a picture and I cant get to any other modes or setting , how do I fix it . thanks
Teresa Skeenes - Reply
