Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Battery/Charging Issues
Power button is pressed and nothing happens
• Make sure battery is charged
• Make sure battery is inserted correctly
• Make sure covers are fully closed
Battery is dying quickly
• Battery performance decreases at low temperatures. Warm the battery up then insert back into the camera
• If temperature change of battery did not fix the problem then the battery life is over. Replace the battery
Lens not retracted
• Close the cover, turn the camera on and then turn it off again
Shooting
Cannot shoot
• Switch from Playback mode to shooting mode
Shots are blurry
• May occur when touch shutter is used to shoot, depending on shooting condition. "Hold the camera still"
• Make sure object is within focus range
Shots are too dark
• Set the flash mode on
• Adjust the brightness by using exposure compensation
• Reduce the lighting on subject
Errors Shooting Movies
Time elapsed time shown is incorrect
• Switch to a card that supports high speed recording
Playback Problems
Playback is not working
• Image may not be possible if a computer is used to rename files or alter the folder structure.
Sound not playing during the movie
• Adjust the volume, or if the mute setting is on
WIFI
Wifi symbol not being displayed
• Wifi menu not available in shooting mode, switch to playback mode and try again
• Touch the screen to switch to simple information display
• The wifi symbol will not be displayed while the camera is connected to a printer or computer
Cannot send images
• The destination device has insufficient storage space.
• The write protected tab of the memory card in the destination camera is set to the locked position.
0 Comments
