Table of Contents
Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Blender Will Not Power On
The blender fails to respond while plugged into an outlet
Faulty Safety Switch
On the blender, there is a safety switch at the back of the connection port for the blender cup attachments. Ensure that the switch is clean enough to move freely.
Faulty Power Cord
The device is plugged in and the power dial is turned and connected, but the blades do not spin. The power cord may be dysfunctional. Replace the power cord.
Smoke Coming From Motor
While blending, the device has a noticeable burning smell or smoke is seen
Faulty Motor
Your motor has become worn out over time or has been overworked. The next step will be to remove the base of the blender then look for the motor inside. If the motor is connected properly, you will have to replace it with a new one. Follow this guide.
Noticeably Weak Motor
While blending, the user notices the blender is not performing or blending to its usual standard
Blade Assembly Seizure
Your blade assembly has become dirty and no longer turns freely. Check around and under your blades to ensure they are clean. If not, remove any debris with a brush or similar cleaning tool.
OR
Your blade has become bent or deformed to the point where a replacement is needed. The blade will have to be removed and replaced with a new one.
Mechanical Issue Causing Blades Stop Spinning
The blades could be too loose to rotate in the cup when the motor is spinning and may need to be tightened. Check to see if the blades moved when you place light pressure on them. If they do move properly tighten them.
OR
The coupler linking the blade assembly and the motor is failing to connect properly, causing the motor to run without rotating the blades. If the coupler is failing to connect, you may need to replace parts. First, check the connection between the two couplers and ensure they are not stripped. If they are stripped and the connection is not longer strong purchase new couplers.
Faulty Motor
Device Will Not Blend While On
While the blender is noticeably on, the blades do not turn and and the device fails to blend
Faulty Motor
16 Comments
My Cusinart which I’ve had for quite a number of years has worked well …with one problem … after using the TOP sticks to the color and won’t dislodge for hours.  Now, it’s been stuck on for two days.  I’d like to save it if I can cause it’s a pain to research news ones and figure out what will work for me.
b_briemer - Reply
That should say “collar” instead of color.
b_briemer - Reply
I have a cuisine art blender I used once only 2nd time when I turned it on smoke poured from it I never used it again ,as it put it away I never thought about sending it back what can I do
cathrandell - Reply
i HAVE A BRAND NEW CUSINART NEVER USED . iT SAT FOR 7+ YEARS . nOW IT WON’T TURN ON iS THERE A WAY TO FIX IT
Jacqui Minenna - Reply
I also have a brand New cuisinart which I have never used.The motor does not turn on it is beyond warranty. Can I send it to cuisinart for repair
Wilma selenfriend -
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 67
All Time: 17,471
