Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Water will not heat up
Coffee comes out cold or not as hot as it should be.
Disconnected Heating Contact
Open the bottom of the coffee maker and check that the small contacts to the heating element are connected. If they are not making contact or have become disconnected, re-solder the contacts following Heating Element Contact guide.
Faulty Heating Plate
Open the bottom of the coffee maker to check that the small contacts to the heating element are connected. If both points are making contact, consider replacing the heating plate element following the Heating Plate Replacement guide.
Cuisinart will not display time
Your Cuisinart is not displaying the time or the time looks distorted.
Faulty LCD Display
If your Cuisinart is not displaying the time properly, make sure wiring connection is secure on the backside of LCD board. Resecure loose wires into wiring bracket.
LCD Circuit Board is Damaged
Ensure all electrical contacts are clean and intact on circuit board. Damaged components will need to be replaced.
Water is leaking inside Cuisinart
There is water leaking from inside the coffeemaker.
Faulty Hose Connection
Open the bottom of the coffee maker and check if the red hoses are properly connected to the heating plate. If they have become disconnected, use the clamps to reconnect them. If the hose has been damaged, consider replacing them following the Water Hose Replacement guide.
Hose is damaged internally
Water is leaking from the tubing of the hose at any midpoint of the hose. The hose could be cut, split, or is not water tight and needs to be replaced. If the hose has been damaged, consider replacing them following the Water Hose Replacement guide
Coffee is leaking from cofee carafe
Water or coffee is leaking from coffee pot.
Failing seal on lid or handle
If there is water leaking from the carafe ensure the lid is sealed and handel is properly attached. If water is leaking from the lid, you may need to reseal or replace the lid. If water is leaking from the handle you may need to replace the handle seal. To replace the carafe handle follow the Coffee Carafe Handle Replacement guide.
Fractured glass on carafe
If water is leaking from the carafe and not coming from the lid or handel, check to make sure the glass is not stressed or fractured. Fractured or stressed glass needs to be replaced
Cuisinart will not power on
Your Cuisinart is not turning on or off.
Cuisinart is not plugged in
Ensure that the power cord is plugged into the wall.
Power cord malfunction
Look over the power cord to check if there is any visible damage to the cord. Ensure that the power cord is plugged into the wall and there is power to the machine. If not, you may need to replace the power cord.
Circuit board is damaged
If your Cuisinart is not responding or not working properly, you may need to replace or fix the circuit board.
Buttons on faceplate do not work or get stuck
Your Cuisinart buttons are stuck or does not work when pressed.
Buttons have become stuck
If Cuisinart buttons have become stuck and do not return to original position, ensure the buttons are not cracked or damaged. If they are, consider replacement. You may need to remove the buttons and clear around their edges.
Buttons have become disconnected/ have failing connections
Remove the circuit board behind buttons and LCD display and make sure that the metal on the button makes contact with the circuit board. Also, clean the contact to the malfunctioning button to ensure they can properly make contact.
35 Comments
My cuisinart DC1200 Coffee maker leaves a quarter to a third of the water in tank when brewing coffee. What is the problem? How can it be fixed?
BERT MELTZER - Reply
My cusinart is taking 30 minutes plus to brew a 12 cup pot.
Ed and Suzy Epp - Reply
element works and all other parts but will not brew
ph_gillett@hotmail.com - Reply
my Cuisinart will not brew all other parts seem to work what could it be causing this problem
Mine will not brew. Lights come on, getting power, no brewing
Daily Grinds - Reply
