Table of Contents
Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Common DJI Mini 2 Problems
Diagnose and fix the most common problems plaguing your DJI Mini 2 drone with these step-by-step DIY troubleshooting guides.
3 SolutionsDJI Mini 2 Won't Turn On
None of the drone's lights turn on when you press the power button.
Potential causes include the batteries being out of charge, batteries being damaged, or the power button being faulty.
4 SolutionsDJI Mini 2 Batteries Not Charging
The lights on the batteries do not turn on when a charger is plugged in.
Potential causes include the battery being too hot from recent use, a faulty battery, a faulty motherboard, or a faulty charger.
4 SolutionsDJI Mini 2 Charged Batteries Not Working
The drone does not turn on after you insert a charged battery.
Potential causes include a faulty battery, out of date firmware, or blocked, dirty, or broken connectors in the battery port.
6 SolutionsDJI Mini 2 Fails to Hover in Place
The drone is unstable when it hovers in place.
Potential causes include poor compass or controller calibration, damaged motors, body, or propellers, or improper weight.
4 SolutionsDJI Mini 2 Not Connecting to Controller
The controller cannot connect to the drone via Bluetooth.
Potential causes include out of date firmware, or an incompatible phone.
Didn't find your problem?
Check out our forum forum for more troubleshooting help. Maybe someone has already solved the same issue you are experiencing.
Jacob Matos
1,167 Reputation
4 Guides authored
10 Comments
bonjour ,sur mon mini 2 ,la led en avant n'allume plus ,et celle d'en arriere en pesant su le bouton de demarrage la lumiere clignotte mauve puis plus rien mais le drone fonctionne quand meme mais je ne vois pas les lumieres rouge ou verte clignotter ? on peux m'aider merci
robin_lm - Reply
Hi I’m having problems with my mini two drone, on the drone I have two eight lights and a red light, battery’s are full charged, remote is full charged, drone camera working on the phone
Tony Fontana - Reply
I’m having this same issue . Did you happen to find the out what the issue was ?
Jayden -
i have send a dji i paye 92.00 ca for repare
Robin Lemieux - Reply
I’m charging my batteries up for the first time. One has charged but the other 2 are just flashing 2 white lights.
Can anyone please help?
Ange chris ryan - Reply
Past 24 Hours: 5
Past 7 Days: 35
Past 30 Days: 139
All Time: 16,419
