Table of Contents
Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Can not boot into the Operating System
The machine powers on, but does not load Microsoft Windows
Boot into Safe Mode
Repeatedly press the F5 key while the machine is powering on. If the machine boots into “Safe Mode” the hard drive does not need to be replaced, but the software may need to be repaired.
Use this guide to replace your hard drive.
Research Error Codes
Check the error code displayed. If the display shows “Operating System Not Found” verify or replace the hard drive.
Time is not accurate
The clock's time is not correct
Verify the time zone setting
Assure your timezone is set properly
Verify and replace the CMOS Battery
The CMOS battery is a small button or “watch” battery that keeps power to the internal clock. When this battery dies the machine will not keep accurate time. Consider replacing this battery. Follow this guide to replace your CMOS battery.
Battery will not charge
The battery will not hold a charge
Faulty AC Adapter
Run the computer with the ac adapter in. If computers runs without issue the AC adapter and charging mechanisms are working.
Faulty Battery
If the battery fails to hold a charge with a working ac adapter, replace the battery. Use this guide to replace the battery.
Inability to Connect to Wireless Networks or Slow Wireless Connectivity
The connection to the internet seems slow and obstructed
Test the Wireless Signal
Bring the machine close to the wireless access point. If the problem persists, test the connection to the internet with another device or machine not connected though the wireless device or with a different wireless device.
Replace the Wireless Card
The card may be faulty, consider replacing it. Use this guide to replace the Wireless card.
Slow Operation In Microsoft Windows
Software operates slowly, or slower than usual
Verify your Software Installation
Scan for issues using anti-virus software and install the latest Windows Updates.
Add RAM
Adding more RAM will increases the rate software can operate. Consider adding more RAM. Use this guide to reparable or add RAM.
William Brum
755 Reputation
5 Guides authored
2 Comments
I try to ignit the laptop but it doesn't ignit at all, I think there are an electronic fault in the ignition ciruit. I 'm sure the battery and charger are working the battery led lites, bu t in vain I push the bouton, nothing at all. can anybody help me what to do?
izzeddin Lhassan - Reply
i have problem booting my laptop, dell inspiron 11 3000 series, d battery is inbuilt so i can't remove it..the lcd is blank nd d fan wouldn't start but it's charging
rosheeeda - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 14
All Time: 1,409
