Table of Contents
Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Venue 8 Will Not Turn On
Venue 8 screen won't light up, device won't boot up
Bad Power Supply
Ensure that the Venue 8 Tablet’s battery is not dead, and can hold a charge. Attempt to charge your device and try to turn it on after a few moments of charging. If the device wont turn on due to a bad power supply, you may need to replace the battery.
Bad Power Button
If Venue 8 wont respond to the power button, there may be a connection problem between the power button and the mother board. If this is the issue, you may use this guide to replace it.
Venue 8 Audio isn’t Working
Sound is distorted or isn’t working at all
Speakers have sustained damage
When sounds are distorted (popping, scratching, muffled, etc.) or have stopped working, the speaker in the tablet may have become damaged and is unable to work. If you hear any of these distortions the speaker may be damaged or broken. Use “this” guide to replace the speaker in the Dell Venue 8.
Venue 8 Won’t Charge
Venue 8 won't respond to charger
Bad Power Supply
Venue 8 is Not Plugged In
Ensure that the device is plugged into the electrical outlet or USB port, correctly.
To avoid charging issues, use official chargers with the tablet.
Touchscreen Doesn’t Work
The front screen won't respond to touch commands
Unclean Touchscreen
Ensure that the touchscreen is clean from debris. Use a touchscreen cleaning cloth or microfiber cleaning cloth to clean off any debris that may have gotten on the Venue 8.
Bad Touch Digitizer
If the screen will not respond to commands, there may be a problem with the Touch Digitizer. This guide will help you replace the screen.
Venue 8 Cameras Won't Function
The Venue 8 cameras won't feed image or display proper image.
Venue 8 Cameras are Damaged
Venue 8 cameras may be damaged. To replace the cameras, follow this guide.
Andrea
1,071 Reputation
5 Guides authored
USF Tampa, Team 9-2, Leahy Winter 2015 Member of USF Tampa, Team 9-2, Leahy Winter 2015
USFT-LEAHY-W15S9G2
3 Members
12 Guides authored
6 Comments
well none of these sounds like my problem when i try to turn on my dell venue 8 by android it turns on fine but then start cutting in and out then goes to a black screen with colered lines on the bottem of the screen how do i fix if possible or whare do i send it to fix it.
Damien Valencia - Reply
Hi this sounds like a GPU issue, usually you would need to send this off to get it repaired, however it's probably a replacement motherboard that would be fitted to fix this unless you can find somewhere that can re-flow the GPU chip.
figjamuk -
my screen was cracked so I took it to get fix and they replaced the glass I don't know if that included the motherboard but when I got it home and charged it up I couldn't remember my password so I tried resetting it which seemed to work but then then the screen went dark and now it won't turn on in fact when I try to turn it on the dell sign flashes for a split second followed by a pitch fork symbol for a sec and then shuts off
Nikki - Reply
my dell pro 8 will not charge....when I press power button orange light comes on for a few seconds
vanpaul1 - Reply
I have forget pattern lock. Dell vanue 8 doesn't go to hard reset manu. Please help me.
Sohail Ejaz - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 13
All Time: 11,509
