Earbuds Noise Canceling Not Working
  • Ensure Active Noise Cancelation is On: Some headphones that feature active noise cancellation also feature other audio features, like Transparency Mode or Adaptive Audio, in the case of AirPods. Ensure Active Noise Cancelation is on in your audio or headphone settings. This will be specific to your earbud model.
  • Restart your Device/Earbuds: Often, restarting the device is enough to fix the issue. Restarting your device also restarts the underlying software controlling services like Bluetooth, clearing up any temporary glitches impeding Bluetooth functionality.
Causes
Solution: Make sure your headphones are being worn properly and have a good seal
Most earbuds have several sizes for their ear tips, which help create a seal between your ears and the headphones to create the best sound experience. Some high-end earbuds use software to help determine the best size for you, but if this isn't the case, you might need to determine the best fit manually.
  • Try gently putting your fingers in your ears, starting with your smallest finger. Move to the next finger on each hand until you get a good seal and the outside noise sounds muffled. Then, try to match the size of that finger to one of the provided ear tip sizes.
  • Start at the biggest ear tips and go down sizes if uncomfortable. Also, insert them as deep as you can if you think there's more nozzle to push inside but can't go down ear tip size.
2
Clean exterior microphone and speaker mesh
If you encounter a decrease in bass sound or an increase in background noise when using Noise Cancellation, your earbuds may require cleaning. Noise cancellation works by using external microphones to detect ambient noise, then generating an "anti-noise" wave that is the inverse of the original sound wave, effectively canceling it out. If the external microphones become dirty, this can affect how well your Noise Cancellation works.
  1. Add a small amount of micellar water to a cup.
  2. Dip a soft-bristle toothbrush in the cup of micellar water until the bristles are fully saturated.
  3. Hold your earbuds with the mesh facing up.
  4. Gently brush the mesh in circles for about 15 seconds.
  5. Turn over your Ear Bud and blot it on a microfiber cloth. Ensure the cloth contacts the mesh.
  6. Repeat steps 2-5 twice (three times total) for each mesh you would like to clean.
  7. To rinse off the micellar water, rinse the brush with distilled water, then repeat steps 1-5 with distilled water for each mesh you cleaned.
  8. Allow your earbuds to dry completely before you place them in the charging case or use them.
Important!
Never submerge your earbuds or the charging case in cleaning solutions or water. This can cause damage to the electronics inside your ear buds
3
Solution: Forget and Re-Pair your Earbuds
Bluetooth devices generate keys and metadata stored on your phone for automatic connection. On Android, this data is written in a system file typically named bt_config.xml, while on iOS, pairing information is stored in a secure part of the system's storage and integrated with the keychain and Secure Enclave. If this data is lost or corrupted, re-pairing is recommended.
  1. Go to your device’s Bluetooth settings.
  2. Find your earbuds in the list of paired devices.
  3. Select Forget Device and confirm.
  4. Put the earbuds back into pairing mode and reconnect to your audio source.
4
Solution: Update Earbud Firmware
Firmware is specialized software embedded in your earbuds that enables communication between hardware and software. In many cases, outdated firmware might have glitches that lead to frequent disconnections or pairing failures. If your earbuds support it, try updating their firmware.
Updating AirPods/AirPods Max Firmware
  1. Ensure that your AirPods are within Bluetooth range of your iPhone, iPad, or Mac connected to Wi-Fi. Place your AirPods in their charging case and close the lid.
  2. Connect the charging cable to the charging case and plug the other end into a USB charger or port. You will plug your headphones in if you're trying to update your AirPods Max.
  3. Wait for the firmware to update for at least 30 minutes. Don't open your AirPods case during this time.
  4. Reopen the charging case lid to reconnect your AirPods to your iPhone, iPad, or Mac. You can verify the firmware version once more through your Bluetooth settings.
Samsung Galaxy Buds
  1. Insert the earbuds into the charging case, leaving the lid open.
  2. Navigate to and open the Galaxy Wearable app on your phone or tablet, and then tap Earbud settings or About earbuds.
  3. Tap Earbuds software update, and then tap Download and install. If an update is available, the update process will begin.
In some instances where updating the firmware isn't possible, you might need to factory reset your earbuds.
5
Solution: Repair or Replace your Earbuds
If, during troubleshooting, you notice physical damage to your earbuds' speakers, you might need to consider repairing them. Earbuds have a lengthy and tempestuous history when it comes to repairability. However, if you have some micro-soldering skills, consider checking out some of our incredible guides.
View statistics:
Past 24 Hours:10
Past 7 Days:43
Past 30 Days:153
All Time:1,308
