Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Tablet Will Not Turn On
Faulty Battery
If your Ematic will not hold a charge or is dead, the battery might be drained. Charge your Ematic, by plugging it into your computer or AC adapter. Your Ematic should begin to charge its battery. The charging light should be on. If the Ematic will no longer charge, you will need to replace the battery. You can use the battery replacement guide: Ematic EGQ307 Battery Replacement.
Flattened Battery
Your battery may have become "flattened" to where it can't accept charge from the wall charge. Try trickle charging your tablet from a low voltage connection. Trickle charging is where you charge the battery at much lower voltage than normal. Lithium based batteries are known to be highly sensitive to overcharging, which may prevent the battery from holding charge. A low voltage charge can be a PC USB port, or a low powered phone charger. Try to trickle charge for 8 to 10 hours.
Screen Is Blank or Distorted
Loose Touchscreen
The touchscreen can come loose and no longer connect properly with the motherboard. This can happen when the tablet becomes jostled or handled roughly. If the touchscreen is lose, you will need to remove the touchscreen, and then reattach it to the motherboard correctly. Use the following guide: Ematic EGQ307 LCD Replacement, for instructions on removing the touchscreen.
Software Issue
If your screen is blank and has no signs of damage or distortion, the problem may be software related. Make sure your Android OS is up to date. If necessary, try doing a Factory Reset, but make sure to back up any important files first.
Faulty Touchscreen
The touchscreen might simply be faulty and need to be replaced. Use the following replacement guide: Ematic EGQ307 LCD Replacement, for replacing the touchscreen.
There Is No Sound
Faulty Speaker
Your speaker might be blown, or the connecting wires might be lose. If either scenario is the case, you will have to open your tablet and repair or replace your speaker. You can find instructions for how to replace your speaker using this guide: Ematic EGQ307 Speaker Replacement.
Software Issue
Issues with the audio on your tablet might be software related. Before opening your tablet, you should make sure your Android OS is up to date. If that doesn't work, do a Factory Reset; make sure you back up anything you want to save.
The Camera Is Not Working
Software Issue
If your camera isn't working or only giving you a black screen, this may be an issue with your camera app. Try reinstalling it and make sure your Android OS is up to date. Restart your tablet. If none of these options work, perform a Factory Reset. Remember to backup anything you want to save.
Damaged Lenses
Sometimes the lenses on your camera may be damaged by hard impacts or scratches. You can replace your camera using the camera replacement guide: Ematic EGQ307 Front Facing Camera Replacement.
Damaged Digitizer
Replace Screen
If your digitizer screen is cracked or broken, you will need to replace it to prevent further damage and put your touchscreen at risk. Use the digitizer replacement guide. Ematic EGQ307 Digitizer Replacement
10 Comments
will not go to factory reset
herbert berkshire - Reply
I can't get pass the ematic screen I've try the factory reset. It will not reset
When I try to install apps on my tablet, it keeps saying: unknown error code during application in stall:"-504". What does this mean???
Lori Stross - Reply
my laptop show battery line win turn it on
isabellacharlesbabineaux77 - Reply
I push the power button and the light blinks and doesn't turn on
Chyrelle8 - Reply
