Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Battery won't Charge
The battery does not hold a charge and dies quickly.
Loose charger:
Ensure the charging port is correctly inserted into the Garmin Drive 52 and Traffic if the port is not inserted correctly into the Garmin Drive 52 and Traffic then no charging will happen.
Faulty Charger:
A poor charging cord will cause cause the Garmin Drive 52 and Traffic to not charge. Examine the charging cord for any damage, replace cord if any damage is found.
BMS Failure:
A BMS failure could mean the battery is overcharging which can ultimately lead to poor battery life.
If Garmin Drive 52 and Traffic is on the charger for excessive amounts of time this could cause a BMS failure because the battery is being overcharged. When charging the Garmin Drive 52 and Traffic make sure to unplug the cord once the Garmin Drive 52 and Traffic is fully charged to avoid overcharging.
Faulty Battery:
The older a battery is the weaker the battery life, resulting in fast draining battery. If the Garmin Drive 52 and Traffic is significantly aged replace the battery with a newer one.
Frozen Display
The display flickers or freezes.
Device Needs to be Reset:
If the screen suddenly freezes or glitches this could be a malfunction in the display. Reset the Garmin Drive 52 and Traffic to resolve the malfunction.
Device is Not up to Date:
A software update is essential in making sure the Garmin Drive 52 and Traffic is up to date and has any bugs fixed. If the display on the Garmin Drive 52 and Traffic freezes and crashes the Garmin Drive 52 and Traffic could potentially need a software update to function normally again.
Interior of Device is Dirty:
If Garmin Drive 52 and Traffic has collected an abundance of dust this can cause the system to over heat leading to display freezing and flickering. If Garmin Drive 52 and Traffic has noticeably collected dust remove the dust.
Distorted Audio
The sound is distorted or no sound comes out of the speaker.
Device is in Silent Mode:
If the Garmin Drive 52 and Traffic has been placed into silent mode this will cause no sound to come out of the speakers. Enter the audio settings mode on the Garmin Drive 52 and Traffic and ensure the audio is not muted.
Loose Wire Connection:
If all the wires are not secured into the Garmin Drive 52 and Traffic this will cause distorted sound or no sound to come out of the speakers. Check all the wires connected to the Garmin Drive 52 and Traffic and ensure they are all secured into their ports.
Burnt Voice Coils:
If speakers have a burnt voice coil this is often the cause of a distorted sound coming out of the speaker. Replace the coils in the Garmin Drive 52 and Traffic if they are burnt and ensure the amplifier isn't set too high for output sound by going into audio settings. This will prevent future burnt voice coils.
Unresponsive screen
The device displays a blue screen and the device stops working.
The Garmin Drive 52 and Traffic may have experienced an error within the hardware that caused a sudden blue screen, reset the device to resolve this error.
Software Update is Needed:
Not keeping the Garmin Drive 52 and Traffic up to date will allow more bugs and errors to happen which will cause a blue screen. Make sure the Garmin Drive 52 and Traffic is currently up to date with the latest updates to prevent these errors from happening.
Screen is Faulty
The screen needs to be replaced. Follow the Garmin Drive 52 and Traffic Screen Replacement guide.
Sources:
https://www.takomabattery.com/why-is-the...
https://bristeeritech.com/it-security-bl...
https://support.garmin.com/en-US/?faq=H3...
https://www.businessinsider.com/guides/t...
2 Comments
strap afix to garmin is broken need replacement
charles swallow - Reply
will not fit or stay connected to stand on auto is broken
