Student In Progress
This wiki is being worked on by hardworking students.
HP 14-dq5043cl Does Not Power On
HP 14-dq5043cl doesn’t turn on or register any input.
Not Plugged In properly
Sometimes the charging port can be blocked by something.
- Verify cord is securely in the charging port and not being interfered by any blockages
Faulty Battery
If charging doesn’t provide power, you may have a faulty battery
- Verify the location of the battery and ensure it is secured properly and not out of place
- If charger still does not provide power replace the battery with a new battery
For support on how to replace a faulty battery refer to our battery replacement guide.
Ram Damaged
If a major component such as the ram is damaged that can lead to trouble booting up
- Locate the area in which the ram is stored in the laptop
- Ensure the ram is secured and plugged in properly
- Clean off any dust to prevent any overheating issue
In the event your ram is damaged or in need of repair our replacement guide will provide the upmost assistance.
Broken Storage Device
The storage device is responsible for holding all the important information on the device, including the operating system. If damaged the computer may not boot.
- Locate the storage device for your device
- Take out the Storage device and clean it off
- Put it back in place and try to turn your device on
- If it still doesn’t work, you will need to replace your storage device
Refer to our replacement guide for storage devices in the event you need any assistance with said issue.
0 Comments
