Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Power Cord Will Not Fit into Printer Power Plug Input
Power cord will not plug into printer.
Objects Obstructing Plugin
Visually inspect and remove any obstruction in the power plug, possibly clean plug of any dust or debris with a dry rag.
Faulty Power Cable
Check power cable to assure it is the correct cable. Look for visible tears, rips, or damages along the cable.
Bent Power Plug Input Prongs
Check to see if the power prongs are straight on the printer, if not bend slightly to attempt to realign the prongs.
Missing or Damaged Power Plug Input Prongs
If you are missing a prong or have a damaged prong, and the power cord no longer fits into the machine; you will need to remove the power plug input and replace with a new one that you purchase. Click Here to view the guide on how to remove the damaged Power Plug Input.
Paper Will Not Feed into Printer Correctly
Rollers activate but paper does not feed into the printer.
Paper Jammed in Printer
If paper is visibly stuck within the printer, attempt to remove the paper manually out of the paper input.
Paper not Jammed, but Paper Still will not Pull into Position
If this is the case, you may need to re-position or replace the paper feeder spring. Follow our step by step guide here to replace the faulty spring.
Paper not Jammed, Spring is in Place, Rollers Sounds can be Heard, and Paper is still not Feeding Correctly
If you have used all previous options with no results you may have to replace the drive belt. The drive belt replacement guide can be found here.
Overall Systematic Printer Dysfunctionality
Major difficulties with the printer that cannot be explained with surface examination.
Motherboard Short Circuited
Possible Symptoms of Motherboard Failure: (Home Power Surge or Lighting Strike)
Printer Buttons not Working, while Lights are On
If HP LaserJet P1102w printer buttons are not working but the lights are still on for the buttons the motherboard might be damaged and will require replacement.
Failed Lighting
If your HP LaserJet P1102w printer buttons are not lighting up but power appears to be flowing through the printer the motherboard might be damaged and will require replacement.
Failure to Recognize Computer / Network
If your HP LaserJet P1102w printer cannot connect to the network but has all the required drivers and software updates the motherboard might be damaged and will require replacement.
Ink Incorrectly Coping onto Page
If your HP LaserJet P1102w printer is incorrectly printing out your document, you may need to replace the motherboard.
If you are experiencing any of these issues or have further systematic failures, you may need to replace the printer's motherboard. Follow our guide here for instructions on replacing the motherboard.
11 Comments
Wow your groups reputation is so high!
Dillon Keller - Reply
my printer is not tirning on but everything fits in fine
Umar Faisal - Reply
Paper not feeding in and yet it keeps on saying paper jammed. checked it up but no paper or foreign matter found in paper track.
braverly.p.torao - Reply
printer makes a loud noise when turned on
shannon peters - Reply
HP LaserJet P1102W Printer is one of the incredible printers that fulfills all the printing requirements wirelessly. But sometimes, users face the issue of ***HP LaserJet P1102W not printing properly***. So, to resolve the issue, you can check the device manager warning. Whenever an error is found in your computer or printer, the Device Manager will show a yellow warning triangle next to the USB controller’s entry. So, you need to resolve the issue on the computer before the printer detects it. And, if it reformatted the computer, then the printer driver was not installed properly, or your USB port is not working. In this situation, check the computer’s manufacturer for resolutions with the USB ports. And, you can also reset the printing system but beware that it will remove all the existing printer queues and will also reset the customized driver settings. You can also perform ***HP LaserJet P1102W manual setup*** to resolve the issue.
Read More
***HP LaserJet Pro M15W Printer Setup Wirelessly***
The Global Blogs - Reply
