Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Short Battery Life
Laptop’s battery is drastically shorter than what it should be.
Laptop Is On High Performance
The battery gets drained if the laptop is on high performance at all times. To solve this click the battery icon on the bottom right and move the pointer to the best battery. Instead of the laptop working for the best performance it’ll be on battery saver.
Faulty Battery
If the laptop continues to have a short estimated battery life it may be due to overcharging and the battery must be replaced. Replace the battery using this guide HP Notebook 15-ba018ds Battery Replacement.
Touchscreen Does Not Work
When the device is on, everything looks normal, but the screen fails to respond to touch.
Dirty Screen
The screen is sensitive to any outside interactions. There may be a smudge that can’t be seen with the human eye. Turn off the laptop and then take a dry cotton cloth and wipe down the screen gently. Spray minimal Windex on the cloth and repeat wiping.
Internal Cooling Fan Does Not Work
Laptop overheats or unexpectedly turns off.
Low Battery
In some cases when a laptops battery percentage reaches a certain point, the internal fan will automatically stop working due to a low power supply.
Heavy Dust Accumulation
Over the course of laptops, life dust can accumulate between the blades of the fan causing it to either overheat or stop moving altogether. To remove the fan use this guide HP Notebook 15-ba018ds Fan Replacement.
Wifi Disconnects
The Wifi is connected, but there is no access to the internet.
Reset Your Router
Unplug your router from a power source for about 20 seconds. This should reset the router connection to your internet provider.
Bad Wifi Chip
Try seeing if any other electronic devices connect to the internet. If the other devices connect, then you might have a bad Wifi chip. To replace your Wifi Chip you this guide HP Notebook 15-ba018ds Wifi Chip Replacement.
Low Storage
Ram is full of storage, lags the laptop.
Replacing Ram
The ram can become full over time and should be replaced. The ram can be removed using tweezers from home while powering off the computer completely. When continuing the steps below, the task must be handled on a flat and clean surface. Use this guide HP Notebook 15-ba018ds RAM Replacement to help you replace the RAM.
0 Comments
