Causes
Ensure that the Motor is properly connected, and if not connected. If that does not solve the issue then try replacing the motor. To replace the motor, follow the Haiboxing 18859 Motor Replacement Guide.
- 25 - 30 minutesModerate
The servo is the part of the car responsible for turning the wheels. It should be noted that only the front wheels should turn. Make sure that the wheels respond to the controller and if not, try replacing the servo. To replace the servos, follow the Haiboxing 18859 Servo Replacement Guide.
Haven't found the solution to your problem?Browse our forum
