Haiboxing 18859 Does Not Sync to Remote
NMiedema and 2 contributors
Last updated on
When using the remote of your Haiboxing 18859, does the RC car dos not respond to the input? Follow these steps to get your RC car and remote properly connected.
Causes
Ensure that both the car and the remote are switched on.
2
Ensure that the RC car is charged. If it isn’t, plug it in to fully charge it.
3
The batteries inside of the remote may be dead. If so, replace the AA batteries inside of the remote.
4
The cable used to charge the car may be broken. Try replacing the cable to charge the car. A replacement cable manufactured by Haiboxing can be found here.
5
Remove the plastic body shell of the car. Check that the red plastic receiver inside of the car is properly plugged in. To see photos of how the RC car receiver should be setup, view the Haiboxing 18859 RC car receiver replacement guide.
6
The receiver inside of the car may be damaged. To check, remove the plastic body shell of the car to see the receiver. To replace the receiver, follow the Haiboxing 18859 RC car receiver replacement guide.
7
The battery of the remote, car, or both may be damaged. These will need to be replaced. To replace the battery of the remote, follow the Haiboxing 18859 remote battery replacement guide. To replace the battery of the car, follow the Haiboxing 18859 RC car battery replacement guide.
View statistics:
Past 24 Hours:1
Past 7 Days:8
Past 30 Days:65
All Time:327
