JBL Flip 4 Will Not Charge Or Won’t Hold a Charge
Arielle Sampson and 1 contributor
Last updated on
Does your JBL Flip 4 no longer hold a charge for as long as it used to? Does it not charge at all? JBL Flip 4 speakers are susceptible to a range of problems that could cause them to stop charging or lose charge quickly. Check the following possible causes to identify and solve the problem.
Causes
If your JBL Flip 4’s battery is not charging or unexpectedly turns off, it may have a faulty battery. Before replacing the speaker’s battery, check to make sure that the speaker has not been left in abnormal temperatures, such as near a stove or fireplace. Abnormal temperatures can cause the device to lose battery power more quickly than normal. If the battery issues continue, use the JBL Flip 4 Battery Replacement Guide to replace the speaker’s faulty battery.
2
If your JBL Flip 4 still refuses to charge after replacing the battery, it may have a faulty charging port. To replace the speaker’s charging port, use the JBL Flip 4 USB Port Replacement Guide.
View statistics:
Past 24 Hours:
9
Past 7 Days:
67
Past 30 Days:
363
All Time:
59,654
