Kenmore Dryer Not Heating
Bill Gilbert and 2 contributors
Last updated on
We will first deal with both electric and gas dryers, and then look at electric dryers followed by gas units.
Causes
Make sure your electric dryer is getting proper power.
For your gas dryer, it's simple:
  • Make sure the gas is connected and turned on.
  • The gas valve or cock is turned on if the handle lines up with the pipe.
2
Dryers are equipped with a number of safety devices. Dryers use heat, which not only dries clothes but can cause fires if not tamed. Here's a page with more information on the various safety devices and control sensors.
If any of these safety devices listed below turn out to be the problem, make sure you clean your machine and ducts as shown on our Dryer Maintenance page.
  • Unplug the dryer before performing these checks, as you will be working inside the dryer cabinet.
  • The thermal fuse could be the cause of no heat, but in most cases, the machine won't run at all if it is blown. Here's more info on how to check the thermal fuse.
  • Kenmore dryers also have thermal cutoffs.
    • They act like a fuse and trip and are not resettable.
    • Unlike the thermal fuse, the machine will, in many cases, still spin if this is blown.
    • On electric dryers, the thermal cutoff is usually located near the heating elements.
    • Gas dryers have a thermal cutoff located on the duct where the heated air enters the dryer drum.
    • Check it with a multimeter for continuity. If it is open, replace it.
  • There is also the Hi-Limit thermostat.
3
This is another item that the electric and Gas dryers have in common.
  • This thermostat controls the temperature inside the dryer by turning on and shutting off the heat source.
  • It should show continuity at room temperature.
  • Test it with a multimeter. If it is open, replace it.
    • The cycling/operating thermostat should be located at the back of the dryer behind the rear panel in most models.
4
Your Kenmore Electric dryer may have a burned-out heating element.
It will be located in the back cabinet of the dryer on most models. To check it:
  • You will need to disconnect it from the wires leading to it. If there are more than two wires coming from the machine to the element, it may be a multi-coil heating element. More below on that.
  • Measure the resistance with a multimeter. It should register 10-20 ohms (Ω)
  • If the element shows a much higher resistance (over 50 Ω) or an open circuit it should be replaced. A High resistance (over 30 Ω) may be a sign of a multi-part element. See below.
Some elements may be set up with two (or more) parts. If one goes bad, the dryer will still dry, but much more slowly.
Multi-coil Heating Elements will usually have 3 terminals (or more if there are more than 2 coil elements) where the heater coils are connected to the dryer. Each coil element will usually have the same resistance but occasionally can have different resistance values for each coil. Usually, there will be one "common" terminal and two coil terminals. We will assume 2 coils for the test below.
  • Measure the resistance of each coil to the common terminal. It will be usually in the 20-25 Ω range.
  • Measuring through both coil terminals should give double the resistance of measuring through one coil terminal and the common terminal.
  • If it checks out go on to the next applicable item.
5
Your Kenmore gas dryer may be having a problem with igniting the gas flame. Since this is a more complex series of events we will just run over the basics here. Here's a link for the full information on Ignition System Failure, including testing. You may need to operate your dryer with some of the cabinet parts removed so use caution.
  • Your gas dryer uses an igniter to ignite the gas.
  • The gas valves don't open unless the igniter appears to be hot enough.
  • The device which senses this and allows the gas valves to open (and keeps the flame going) is called the flame sensor.
  • The gas valves may not open because the solenoid coils which operate them have gone bad.
  • The gas valve itself may have failed.
6
  • The moisture sensor wiring may be bad and give the dryer an open circuit indication (no wet clothes) and the dryer won't heat on the automatic cycles but will likely heat on the timed dry cycles.
  • The timer may be bad, and it is a good idea if all the other tests show no problem to test the timer contacts.
  • The centrifugal switch on the motor may have failed which will make the dryer act as though there is no airflow (no motor turning means no airflow) and it will not allow the heat source to operate.
  • On electronic models, the main control board may be bad. There are diagnostic procedures available on the tech sheet enclosed in your dryer's cabinet.
Excellent video on Gas Dryer Won't Heat Troubleshooting from Sears Parts Direct.
Good Video on Electric Dryer Won't Heat Troubleshooting from Sears Parts Direct
Helpful, but long video on electric dryer troubleshooting on Kenmore Elite Heavy Duty King Size Capacity built in 2006 having no heat.
View statistics:
Past 24 Hours:
6
Past 7 Days:
53
Past 30 Days:
243
All Time:
18,872
