Table of Contents
Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Kurio Thrive won't turn on
No matter what you do, you can't get your Kurio Thrive to turn on.
Defective battery
If your Kurio Thrive won't turn on, or turns on while it is charging it could be due to a defective battery. For help on how to replace it click here
Battery is dead
Before taking apart on your device, try to make sure that the battery is charged.
Bad LCD
It is possible that it nothing appears on the screen because the LCD is broken. If you can hear your Thrive operating (while charging or without), but nothing is happening, it is possible the LCD needs to be replaced.
Kurio Thrive will not charge
You can't get your Kurio Thrive to hold a charge.
Bad battery
If your Thrive doesn't charge, the reason could be because the battery is bad. Attempt to replace your battery before trying to take your Thrive apart.
Broken charger cord
If you plug in your Thrive and it does not turn on or charge, it's could be that your charger cord is not working properly. Attempt to use the cord on another device to make sure whether it is working or not.
Broken charger port
If you plug in your Thrive and it does not turn on or charge, it's possible that your charger port has something stuck in it or broken. Attempt to remove whatever may be blocking the port from functioning. If there is nothing in the port, it may have to be replaced. Attempt to look on the step-by-step instructions here.
Screen doesn't work
Your screen produces distorted images is cracked, or doesn't come on
Broken LCD
If the LCD is still producing distorted images or doesn't come on it should be replaced.
Cracked Screen
If the touch screen of your Kurio is cracked, the glass cover needs to be replaced. For instructions, click here.
Discharged battery
Attempt to plug in the device to a power source to know that a dead battery isn’t the cause of the problem.
Camera doesn't work
Your camera produces distorted pictures does not take pictures, or won't turn on.
Broken camera
If the camera does not take pictures or do not work, the camera may have to be replaced. For instructions, click here.
Dirty lens
Look for dirt or fingerprints on the the camera lenses it should be free of any obstacles.
Distorted or no Audio
There is distorted or no sound coming from your device speakers.
Distorted sound
The speakers are defective or may have liquid into it that causes it to malfunction. You can get steps to do this here.
Speakers are off
Try to make sure that your device is not muted and the speakers are on. Attempt to turn all volumes to the highest possible through your settings. If sound is not there, the speakers may need to be replaced.
Khalid AlTamimi
275 Reputation
2 Guides authored
USF Tampa, Team 6-5, Brown Winter 2015 Member of USF Tampa, Team 6-5, Brown Winter 2015
USFT-BROWN-W15S6G5
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 173
