Projector is outputting no image and no sound
Check power source connection on device or outlet
Make sure the projector is turned on and the volume is turned up
If the projector is still not outputting any image or sound, try unplugging the projector. Leave unplugged for 30 seconds and then plug projector back in and restart. If there is still no signal, chances are you need to replace the light bulb. See Merch Source Projector Entertainment II Light Bulb Replacement.
Projector fan is running but no image output
Light bulb interference or defection
This make and model has a history of poor light bulb function. If you shine a flashlight through the rear panel, where you access the bulb, you should be able to diagnose the problem depending if the video output is visible or if the flashlight doesn't project an image.
Video output visible
The bulb isn't working properly. For a bulb replacement guide go to Merch Source Projector Entertainment II Light Bulb Replacement.
Flashlight doesn't project an image
The motherboard or the lens is defective. To replace the lens refer to Merch Source Projector Entertainment II Outer Lens Replacement,To replace the motherboard refer to Merch Source Projector Entertainment II Motherboard.
Projector has image output but muffled/no sound
Check that all the cables are in the correct ports and fully plugged in
Audio isn't getting transferred from computer to projector
On your laptop, go to the control panel. In the control panel, navigate to hardware & sound. From there, go to sound. The output should be set on Digital Audio (S/PDIF).
The audio is still dysfunctional
The speaker or motherboard isn't working correctly. Refer to Merch Source Projector Entertainment II Speaker Replacement if a replacement is desired.
Projector image is blurry
Make sure the lens is in focus
Set the image to a still image and focus the image by spinning the lens casing. Make sure the distance from the projector to the projection wall is not more than 14 feet. If the problem persists, go to the side of the projector and adjust the contrast and color knobs.
Try cleaning the lens
First, try to clean the lens using air. If problem persists, try a dry soft cloth. Do not use fluids of any kind.
Lens is broken
If the lens in your projector is broken or damaged you will need a replacement. See Merch Source Projector Entertainment II Outer Lens Replacement for help in replacing the lens.
Projector shuts off while in use
Check that the projector is plugged in
RCA and video outputs got disconnected
Oftentimes users think their projector breaks even though the signal was just lost. Make sure that the input cables are connected
Projector overheated
If machine is abnormally hot or loud during use, chances are the fan isn't working properly. Check to see if the filter in front of the fan is dirty, clogged or blocked. To fix the heating system, you will have to manually clean the vent or replace the fan altogether. To clean the fan vent, try using a cotton swab in between the slats, or use a dry cloth to remove dirt and dust buildup. DO NOT use any liquid. To replace the fan, see Merch Source Projector Entertainment II Cooling Fan Replacement.
7 Comments
Dah,, this repair procedure is so lame.
bob - Reply
I have the 1004127 comes on the menu works stays lit just keeps saying no signal, I could use help
David Bowie - Reply
projector comes on light works i can see the volume and color and contrast control numbers but nothing will project
One Unit - Reply
Great article!
Alex Richter - Reply
I have theĀ 1004127 buyed at USA , can i plug to 220V ?
Alejandro Garcia - Reply
