Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
There is No Sound From Back Speaker
I'm not getting any sound from my back speaker when I try to play music or a video.
Volume is Mute/Set to Low
Try adjusting the volumes. This can can be done using the volume button on the right side. If this doesn't work go into the sound menu. There you will be able to adjust individual volumes such as system sounds or alarm sounds. Adjust the system sound so that it is at least at middle volume.
Headphones Plugged In
Are you using headphones? If so, remove your headphones from the headphone jack and play the sound again.
Bluetooth is On
Be sure to turn off the Bluetooth feature on your Moto G. Sometimes, when the phone is connected to another device via Bluetooth, the phone will play sound through the other device and not the phone.
Damaged/Worn Out Speaker
If none of these solutions work, that may mean that the speaker is damaged or worn out. You may need to replace the speaker on your Moto G. This guide will show you how.
There is No Sound From Headphones
When I try to listen to music or a video with headphones, I don't get any sound.
Headphone Jack is Dirty
Something may be jammed in the headphone jack or there is dust in the jack. The simple solution is to clean it. The repair guide will show you how to get to the jack in order to dislodge the offending object or clean any dust from it.
Headphone Jack is Damaged/Worn Out
The headphone jack may be worn out or damage. In this case, the headphone jack will need to be replaced. Use the guide to learn how to replace it.
Buttons Do Not Work
I can't change the volume or turn the phone off or on using the buttons.
Misaligned Buttons
In this case, you will need to adjust the buttons to correctly line up within their sockets. Following the instructions in the guide will show you how to get to the buttons and what the should look like when correctly aligned in the phone.
Broken/Missing Buttons
If the power and volume buttons on your phone are broken or missing, you will more than likely need to replace them. This is quite simple. This guide will help you.
Phone Does Not Turn On
My phone won't turn on.
Phone Has No Charge
If your phone is not turning on, please try charging it first. You should wait approximately 30 minutes before attempting to turn it on.
Power Button is Misaligned/Not Working
Try plugging your phone into a computer. If the phone says it has a charge, your problem may likely be with the power button. Check the above guide for instructions on how to replace the power button.
Bad Battery
If the phone is saying it has no charge after attempting to charge or is not charging, the problem may be with the battery. This guide will give you instructions on how to replace the battery.
Can Not Take Front Facing Photos
Every time I try to use the front camera, the picture comes out weird or it shuts down the app.
Front Camera is Damaged
If the front camera is dirty, cracked, or has moisture, you will need to replace the front camera. Follow this guide for instructions on how to replace the front camera.
Software Problem
If, when you attempt to use the front camera, it gives you an error message, you should try to do several things: Restart your phone. This will shut down any interfering apps that could be causing the camera to not be reached. Make sure the apps that you are using and the phone itself are up to date. Sometimes an update helps fix any software issues that may creating glitches when using the camera. Is your phone on low battery? Charge your phone to more than 50% before you attempt to use the camera again. Your phone has a power saving mode that may shut down the camera in order to ease the drain on the battery.
3 Comments
Hi,My motog 1st gen's keypad won't show up and bcoz of this am not able to get into my phone since it is password protected..Is it corrupted?? Please help
Saranya Kumandur - Reply
No its not it happened to me and i hold the power button and open ut again and everything worked fine
ΛΕΥΤΕΡΗΣ ΠΑΛΑΤΣΙΔΗΣ -
Moto g 1st gen won’t hold a charge, I tried all of my cords & nothing worked. What do i do?
Len Piegari - Reply
