Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Camera won't turn on
No matter what you do, you can't get your camera to turn on.
Are the battery and the AC adapter correctly connected?
Check the battery and the AC adapter connection and make sure they are connected in their place.
Is the battery sufficiently charged?
Make sure to use a battery that has been sufficiently charged.
Is the REC/power switch slided fully
Make sure the REC/power switch is slide all the way open.
As the power is turned on, it turns off immediately
Is the batter charge insufficient to operate the camera?
Charge the batter or replace it with a charged one.
Has condensation occurred?
This could happen if you carry the digital camera from a cold place to a warm place. The condensation from inside the camera could keep it from turning on. Wait until the condensation disappears and then turn the camera on.
The image cannot be recorded.
The camera can take pictures, but the images are not saving.
Is the memory card inside?
Place the memory card inside the camera.
There is no capacity on the card.
Check the capacity of the memory card. You can delete some images or videos.
Is the REC/power switch slided fully?
Make sure the REC/power switch is slide all the way to the end.
The image is not displayed on the LCD monitor.
The camera is on, but nothing is showing on the LCD monitor
Is the LCD monitor set to off?
Press the [DISPLAY] button to turn the monitor on. The [DISPLAY] button is next to the LCD monitor.
The LCD monitor is too bright or dark.
The monitor is displaying an image, but the image is too dark or too bright to see.
Adjust the brightness of the LCD monitor.
Change the brightness until it is easy to see the images on the LCD monitor.
The flash does not light.
The camera is on, but the flash does not light.
The flash mode is set to forced OFF.
You can go the menu and change the flash mode to AUTO or ON.
The image cannot be played back.
No matter what you do, you can't play the image back.
Make sure that the memory card is inside the camera and placed correctly.
There are no images in the memory card.
Make sure that there is an image in the memory card. You can connect the camera to your computer and check if there is an image in memory card.
Is the playback/power switch slided?
Check the playback/power switch is slided to the right.
The settings are not memorized.
The settings are not memorized after turning the power off.
Check to see if the memory card is in the camera.
1. Press the [MENU] button.
2. Select [SETUP] and the setup menu will be displayed.
3. Select [MEMORY] and choose to be [ON].
4. Press the [MENU] button twice to make the menu disappear.
The LCD monitor cannot be set to off
No matter what you press the LCD monitor will not turn off.
[D.ZOOM] may be set to [ON]
The image is not displayed on the TV.
When connecting the camera to a TV the image on the camera is not showing up on the TV.
1. Check if the camera is connected to the TV correctly.
2. Set the TV to video input mode.
When connecting to PC, images cannot be transferred
The images from the camera are not transferring to a PC.
Check if the camera is correctly connected with the PC.
0 Comments
